Topics49,841
Posts837,327
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
There is enormous variability between petrol pumps and the way they deliver. I have a couple of local filling stations where I can quickly fill the tank with no blow back, others where unless I fill very slowly it blows back and getting the last couple of litres in is virtually impossible.
I don't understand the cause of the difference, but there must be an explanation.
Posts: 625 |
My Jeep JK had this problem. The petrol station pump clicked off every few seconds and it drove me mad, it used to take 10 mins or more to fill the tank, It was a known issue with them and in the end my dealer kicked up enough stink that Jeep flew a tech down to tassie to try and solve it. The problem was the protective wax coating they put on a breather valve on the tank apparently, every time the sun came out and the day got hot the wax would melt and stick the valve. They took it off degreased and dewaxed it, issue solved. Could the Morgan issue be the same?
Cheers John 2011 4/4 - "Elrond" 2007 Elfin C3 Clubman - “Gimli”
Posts: 1,341 Likes: 15
Posts: 1,341 Likes: 15 |
My Jeep JK had this problem. The petrol station pump clicked off every few seconds and it drove me mad, it used to take 10 mins or more to fill the tank, It was a known issue with them and in the end my dealer kicked up enough stink that Jeep flew a tech down to tassie to try and solve it. The problem was the protective wax coating they put on a breather valve on the tank apparently, every time the sun came out and the day got hot the wax would melt and stick the valve. They took it off degreased and dewaxed it, issue solved. Could the Morgan issue be the same? ooh, hot sun melting wax.... if only!
Formerly Aero S5 #80 Currently 911 (992) Targa in python green
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
If you have a Plus 8 with the side screen slot behind the seats, if you remove the rear panel covering the spare wheel hole you will probabably find that the breather pipe runs from the tank to the filler with a pronounced dip. Remove the dip (tie wrap to the cross member above the pipe - with suitable protection to prevent fretting) and this seems to help. Obviously using the well publicised 12 o'clock flap hinge position also helps. You could also reduce the length of the breather pipe to reduce the dip but access with the side screen slot fitted is very restricted.
I don't have a side screen slot - but I may take a look at the kink at some point, assuming I have a kink... Getting fuel into my Aero +8 is about the only gripe I have with it. It's a royal pain and I'd love a solution. The fuel gauge is also hopeless - I sat parked on level tarmac the other day with the engine running and watched it weave all over the place. Totally mad.
+8 4.8
Posts: 1,959 Likes: 15
Posts: 1,959 Likes: 15 |
Owners listed and kingpin's details added ...
21st Century Plus 8 Owners:
1. Deano - September 2012 Sport Green, black leather, sports side exhausts.
2. Peter J: April 2014 Plus 8, Rolls Royce Metallic Bronze, 23300 miles.
3. Milt: Nov 2014 +8 Speedster, Dark-side Black with Traditional Mohair Hood. The force is strong. Side exhausts & 400PS ECU.
4. Neilda: April 3rd 2015. Metallic Sports Sand +8 with mulberry leather/nutmeg piping and walnut. 4,000 very happy and rapid miles already.
5. Zanzibar: July 2015 manual box+8, 2000 miles, Jaguar pastel green, Bobbin blue leather, Side pipes, Speedster wheels and a curled lip.
6. Aeroman: July 2015 Rocket Blue +8 with Goodwood Burnt Red leather. Bubinga wood dashboard. 3752 miles so far, despite much time in the Works.
7. kingpin: July 2015 White Silver with Mulberry hood. Red leather interior with walnut(?) dash. AeroMax wheels
8. JMog: Metallic red with stone leather +8 first registered August 2015
9. Worthers +8: October 2015 +8 Firenze Red with Ivory leather, still in my garage awaiting paperwork from our wonderful DVLA
Plus 8's on order:
Geordie - +8 ordered for 2016 Crunchie - +8 ordered for 2016 PeterG July 2014 Blue Cepheus with black leather, black Aeromax wheels & side exhausts - 8,000 trouble free miles & smiles (mostly, long story, very long).
Posts: 688 |
I have Milt’s Speedster now but noticed he says it has a “400PS ECU”. Anyone know anything about that?
Porsche 981 Spyder V8 Speedster ( 5 years) 4/4 Competition spec (5 years) 4/4 4str Kent ( 10 years)
Posts: 5,654 Likes: 4
Posts: 5,654 Likes: 4 |
The original plus 8 press release quoted 390bhp with the sports exhaust fitted. However its not totally clear what form the sports exhaust took or whether any where fitted.
Martin (Deano)
Posts: 11,524 Likes: 312
Posts: 11,524 Likes: 312 |
I think the "sports exhaust" was a combination of high flow cat-convters as well as sidepipes ? This had an adjusted map on the ECU to match ?
I am only going on secondhand knowledge so mileage may vary.
