Topics49,871
Posts837,681
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
This maybe the cause of one of my "clonks" Good find. But my clonk coincides with loss of traction so is something in the drive process.
Posts: 42 |
My mechanic said my sprocket was worn and recommended replacing it with a new steel sprocket. I did this. It cost me close to $1K US and apparently it wasn't covered by warranty. I thought it was a design flaw (having an aluminum sprocket) and should have been covered by warranty but I let it go. I haven't had a problem but I would probably be having problems soon if I hadn't replaced it.
Posts: 1,490 |
If design flaws were all covered by warranty,the entire auto industry would have vanished around 1910
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
Posts: 8,684 Likes: 413
Posts: 8,684 Likes: 413 |
I have videoed the prop shaft under load and it moves very little even with the rubber mounting kit on the bevel box. I thought maybe it would twist and give some slack to the final drive but it seems not. The search continues! I notice Phil has finally sourced the cause of his grief in the Centa cush drive - posted in Malvern Arms section here.
Posts: 2,539 |
With all the whirrs and shakes and groans i have no idea what is happening back there!
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
With all the whirrs and shakes and groans i have no idea what is happening back there! It got to the point with me that if I don't hear it, I worry. If something suddenly goes silent or behaves wonderfully, it either broke completely or is laying on the road behind me!
I have videoed the prop shaft under load and it moves very little even with the rubber mounting kit on the bevel box. I thought maybe it would twist and give some slack to the final drive but it seems not. The search continues! I notice Phil has finally sourced the cause of his grief in the Centa cush drive - posted in Malvern Arms section here. Looks like a result. http://www.bleazey.co.uk/M3W.html#CushRevised cush drive and additional bearing support. Wonder if a dealer wants to engineer a commercial version?
Posts: 1,075 |
Phil, you're my kind of guy.
If you look at the normal clutch trans setup, you're correct, the flywheel/clutch is supported on a long shaft with many bearings keeping it in true alignment. The trans on the other hand, has a front input shaft that only has one bearing at the trans and the splined end is in the clutch disc.
It would be ridiculous to think that's all that holds the input shaft in alignment. When the clutch is pressed in and the disc is loose, the shaft would fly all over the place. That's why thy have a pilot bearing located in the end of the crankshaft.
This is exactly what you've done with the bushing in the motor side case and the pilot on the clutch side. I often wondered if this would be an issue as it does just kind of stick "out there" without any other support.
I know that you've proven your theory and what you have now works, but I would be leery of the bushing wearing out and getting loose. I know that you've got an oiling system incorporated, but I would think your next and final step would be to make the pilot as small in diameter as you can and still room done on the motor end for the crank nut etc.
Once you get to a small enough diameter, I believe you should be able to source a pre-lubed and sealed roller or needle bearing that the pilot rides in.
I'm not sure is your pilot is aluminum or steel. If aluminum, my fears would be that it would wear quite quickly do to the shock pulses on the motor and the high frequency oscillations back and forth in the cush drive urethane blocks.
I've read the entire thread, but over this long of time I'm not certain how many M3W's have the slipping sensation that still have the old Harley compensator installed.
In the Harley type compensators, they have the BMW rubber flex that bolts to the clutch/flywheel shaft and then to the housing that incorporates the Harley compensator. The motor end of this is also supported radially through the compensator so there is NO end wobble and the clutch/flywheel shaft stays a lot more stable than with the Centa just sticking out there...
I applaud your effort and resourcefulness!!!
Great work.
I know you mentioned the chain size, but are you running an O-Ring type chain? I've been running an o-ring chain on my old Harley for 12 years and after the first adjustment, I've not had to do a thing to it adjustment wise. I do on occasion spray and wipe it down with WD-40, but that's usually just once a year.
Keep the tips coming and drive safely.
Dan
...I've read the entire thread, but over this long of time I'm not certain how many M3W's have the slipping sensation that still have the old Harley compensator installed.
In the Harley type compensators, they have the BMW rubber flex that bolts to the clutch/flywheel shaft and then to the housing that incorporates the Harley compensator. The motor end of this is also supported radially through the compensator so there is NO end wobble and the clutch/flywheel shaft stays a lot more stable than with the Centa just sticking out there...... Good point. In layman's terms: Morgan's re-engineering for the Centa may be incomplete [... so maybe expect a production fix in 2020  ].
