8 members (Simon, Rastus, TalkMorgan, Ian Wegg, CooperMan, yrr13, Alistair, Bunny),
317
Posts837,985
Posts: 180 |
Hi,
I just wanted to introduce myself to everyone having just picked up an Aero S1 today, what a marvellous car, except.......when reversing into my garage slowly, riding the clutch, the gearbox sounds like a bag of spanners - does anyone else get this?
Ian
Posts: 2,050 Likes: 12
Sir S1'a'lot Talk Morgan Expert
Posts: 2,050 Likes: 12 |
The drive train is clunky, surprised you haven't noticed it going forward too
2002 Aero 8 S1 2023 Plus 4 (woman’s)
Posts: 263 |
Aluminium tunnel acts as an echo chamber!!!! Part of the joy to minimise with sensitive clutch control ... was glad I had read about it otherwise would have thought some fundamental issue!
Aero-Ian
Aero 8 Series 1 Defender 90 BMW 330d M Touring
Posts: 5,659 Likes: 10
Posts: 5,659 Likes: 10 |
They all do that sir. You will get used to all the clunk's & clicks, thay form part of the car's character.
Martin (Deano)
Posts: 1,149 Likes: 19
Posts: 1,149 Likes: 19 |
we were told that if we noticed lots of noises just put the hood down and that helps....so that's a quick fix
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
Welcome to S1 ownership! You shouldn't notice any more noise going backwards than forwards ! Is it simply the transmission clunk common to S1's or ???. You'll get used to the transmission snatch after a few miles and learn to avoid it. Keep us posted. Enjoy the car, they are sublime!
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 262 |
If it's any consolation, I have an Aero S5 that's two days old and it sounds the same. Having owned an S3 mind the sounds are oddly comforting :-)
Happy days.
Rob Good things come to those who wait but they've usually been left by those who got there first!
Posts: 1,948 |
My thoughts too. Could the noise in reverse be originating from further back in the driveline, like the diff for example? Moving backwards, the sound/vibration could 'refer' forwards. It is not uncommon for diffs to complain a bit in reverse, especially if turning. In my experience, the racier the car, the more the diff doesn't like reverse. (And an S1 is certainly at the racier end of the scale). If you think it could be the diff, it might be worth checking what friction modifier additive the S1 diff should have, and when this was last done at service.
Stuart "There's no skill substitute like cubic inches."
Posts: 2,033 Likes: 23
Posts: 2,033 Likes: 23 |
Mine used to clunk on gear changes at low speed or pulling away before I got used to the car, now it's minimal.
However it makes no extra noise reversing, and it never sounds like a bag of spanners..
Aero 8 GTN #11
Posts: 180 |
Thank you for all of your reassuring comments & fast replies.
Day 2 of Aero ownership brings sunshine & an empty car park to check out that reserve gear properly.
It does seem fine when the clutch is fully engaged, the issue being confined to clutch engagement/disengagement, & a more gentle & deliberate approach reduces the noise further. I can therefore only think it is down to the unforgiving nature of the drivetrain, although I had not noticed any issues in the forward gears.
Phew, panic over
