9 members (IcePack, TBM, Image, MATTMOG, chanteclair, Tom Sayles, CJB, +8Rich, Moggo), 259 guests, and 78 robots.
+8Rich 75
DaveW 52
Topics49,868
Posts837,631
Moggo
tom+4 Offline OP
Problem
The switch on dashboard is turnig lose
Is there any way to fasten it easy without removing the dashboard
The knob is marked with a leafe
Gr tom
What year & model is it?
assistance: Tom+4 introduced himself some time ago:
[...but wanted to say hi to all the forum members and from last week i bought a morgan +4 2008 racing green duratec 20 l a right hand drive car for Belgian roads i wonder what it is going to give ....]
His Mog:
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
Guessing your dash is similar to the one I have on my 2009 Roadster. If that case, and you mean the rotary knob that controls the fan, than I can confirm that i tightened it numerous times. My dealer puts far to much pressure in the tires, and the rattles induced by this causes the little grub srew to come loose.
This srew sits in the side of knob. To thighten it I use a very small allen key, that just fits through the pannel gaps. This only works if the grub screw is still in.... you can check this by just taking the knob off. If it is missing, well it is somewhere in your Morgan. I found mine in the foorwell.
I would try this first, as the alternative: dropping the dash, is not too complex, but will take more time.
Succes,
Bert
Bert
2025 Plus Six - 1909
2009 Roadster
1983 4/4 4str
Just a note...when I came to fit one of Cain's veneers in my 2014 4/4: you have to remove the dash which is straight forward but I found that neither of my rotary controls had grub screws fitted at the factory !!!!...they were GLUED ON!!!!
What a pain to remove...started off as a straight forward job but turned into a long job.
Never downhearted !!!
tom+4 Offline OP
Thx bert
Problem solved just tightened the little srew from under the plastic cover under the dachboard
Gr tom
tom+4 Offline OP
Thx bert
Gr tom
