1 members (Bitsobrits),
257
103
Topics49,872
Posts837,705
Posts: 108 Likes: 1
Posts: 108 Likes: 1 |
Hi I need to replace my front brake disc`s, can any one recommend a supplier.Can I improve on the original ones. The car is ok at normal speeds but shudders when braking at 80mph +
Posts: 469 |
Mine did that, I had the discs skimmed, a lot cheaper than replacements!!
(or don't drive over 70 mph.....lol....)
2017 Mercedes Benz SLC 200 AMG. 2019 Mercedes Benz GLA 200 AMG Now Ex-Mogger!
Posts: 2,432 Likes: 17
Posts: 2,432 Likes: 17 |
I need some too but will try skimming on the car first. A local company reckon they have 100% success. Melvyn Rutter has a skimming machine. Factory replacements are around £625 from memory but Mulfab had one set left of theirs a few months ago. Let us know how you get on !
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 108 Likes: 1
Do you know any local company that machines the disc's
Posts: 469 |
Lifes motors did mine (southport) bit of drive for you though, I'm sure if you ask your local dealer he may know someone, (they usually take the discs off and send them to an engineers) unless they have the equipment, I'm sure one of the Morgan dealers down south somewhere has the facilities, I seem to remember seeing something in a miscellany mag a while ago, sorry I can't be much more help. whoops, as mentioned above it is Melvyn rutter who has the equipment.
Posts: 491 Likes: 6
Posts: 491 Likes: 6 |
Can the discs on center lock hubs be skimmed on the car? I have just watched a video showing "Procut" skimming and they bolt on the cutting machine, i also have the judder when braking hard.
2015 +4 and 2000 4\4 1981 Lambretta GP225 1960 Lambretta LI 125
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Do you know any local company that machines the disc's Hi Bill, Try Hargreaves enginering in Johnstown Carmathen. But you will have to take the discs in to them.
Posts: 469 |
I believe the judder can be caused by cleaning the car!!! apparently when you have washed the car it is best to run round the block and heat up the brakes, this dries the water out from the discs and pads and stops rust forming behind the pads where they touch the disc. (this then leaves pitting on the disc which causes the judder when braking) Ian
Posts: 263 |
Nick CW James BW ... cleaning is dangerous!!!! Lessons for us!
Aero-Ian
Aero 8 Series 1 Defender 90 BMW 330d M Touring
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
nooooo! it can't be true Ian Now , how can you clean behind the brake pads on a weekly basis........ James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
