Morgan Aero 8
3 members (deano, JohnHarris, Plus Four Guy), 396 guests, and 102 robots.
+8Rich 76
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,873
Posts837,708
Page 1 of 4 1 2 3 4
#402713 26/10/16 02:59 PM
t50 Offline OP
Hi
I need to replace my front brake disc`s, can any one recommend a supplier.Can I improve on the original ones.
The car is ok at normal speeds but shudders when braking at 80mph +
E
E
Mine did that, I had the discs skimmed, a lot cheaper than replacements!!
(or don't drive over 70 mph.....lol....)
2017 Mercedes Benz SLC 200 AMG.
2019 Mercedes Benz GLA 200 AMG
Now Ex-Mogger!
I need some too but will try skimming on the car first. A local company reckon they have 100% success. Melvyn Rutter has a skimming machine. Factory replacements are around £625 from memory but Mulfab had one set left of theirs a few months ago. Let us know how you get on !
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
t50 Offline OP
Do you know any local company that machines the disc's
E
E
Lifes motors did mine (southport) bit of drive for you though, I'm sure if you ask your local dealer he may know someone, (they usually take the discs off and send them to an engineers) unless they have the equipment, I'm sure one of the Morgan dealers down south somewhere has the facilities, I seem to remember seeing something in a miscellany mag a while ago, sorry I can't be much more help.
whoops, as mentioned above it is Melvyn rutter who has the equipment.
Now Ex-Mogger!
Can the discs on center lock hubs be skimmed on the car? I have just watched a video showing "Procut" skimming and they bolt on the cutting machine, i also have the judder when braking hard.
2015 +4 and 2000 4\4
1981 Lambretta GP225
1960 Lambretta LI 125
Ray Offline
Hi Bill, Try Hargreaves enginering in Johnstown Carmathen. But you will have to take the discs in to them.
E
E
I believe the judder can be caused by cleaning the car!!! apparently when you have washed the car it is best to run round the block and heat up the brakes, this dries the water out from the discs and pads and stops rust forming behind the pads where they touch the disc. (this then leaves pitting on the disc which causes the judder when braking)
Ian
Now Ex-Mogger!
Nick CW James BW ... cleaning is dangerous!!!! Lessons for us!
Aero-Ian
Aero 8 Series 1
Defender 90
BMW 330d M Touring
nooooo! it can't be true Ian scared
Now , how can you clean behind the brake pads on a weekly basis........ confused2
James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
Page 1 of 4 1 2 3 4
