10 members (Image, vincentvg, RichardV6, Alan Patterson, Zach, TBM, Mike D, RedThree, paulmog, John V6),
279
Posts838,000
Posts: 27,838 Likes: 763
Posts: 27,838 Likes: 763 |
Steve, when lights come up on modern cars I always think of the older cars I owned where that just wouldn't happen.
What would you have a red charging light and maybe an oil pressure light.
Happy days. Enjoy the brutatlity & simplicity of the AH. John
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
Thank you John. Yes fairly simple but enjoying it very much, considering the lack of technical gizmos it drives really well. It shows that carbs, points and pushrods don't do that bad a job! And greasing only every 3000 mls ! Time will tell if it needs more attention than the plus4.
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
thanks John. Food for thought. I think it was you i saw at Hereford last saturday. i was too busy concentrating on roundabout entry to wave and in any case i had the hood up. Hereford is a nightmare, last time there even my sat nav could not find a away out from there.
Posts: 7 |
if the car runs well, suspect the sensor(s). I had a similar but less regular problem with my Roadster; replacing sensor sorted it
Posts: 188 |
Thanks for the input chaps, i'm going to first try a tank of proper Shell petrol and if that doesn't work have a sensor change. I could always put a bit of insulation tape over the offending light on the dash i suppose.
2004 Silver Roadster S1
Thanks for the input chaps, i'm going to first try a tank of proper Shell petrol and if that doesn't work have a sensor change. I could always put a bit of insulation tape over the offending light on the dash i suppose. Did that with the BMW for 5 years, cant now with new MOT rules.
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
Just a reminder that my 05 Roadster shows weak lambda at MOT time, which this year I improved by replacing the K&N air filter with the original filter. So far I haven't had the engine warning light (touch wood) but I use Shell V Power whenever possible.
Posts: 14,009 |
Thank you John. Yes fairly simple but enjoying it very much, considering the lack of technical gizmos it drives really well. It shows that carbs, points and pushrods don't do that bad a job! And greasing only every 3000 mls ! Time will tell if it needs more attention than the plus4. I was under the impression that it needed more attention around the fuel filler cap!
Thank you John. Yes fairly simple but enjoying it very much, considering the lack of technical gizmos it drives really well. It shows that carbs, points and pushrods don't do that bad a job! And greasing only every 3000 mls ! Time will tell if it needs more attention than the plus4. I was under the impression that it needed more attention around the fuel filler cap! Oh you are right there J, the fuel filler will probably be the first thing to wear out! but if I'd taken it to caramulo at least the fuel stops could have been better aligned with the pee stops! I guess the fuel consumption is one of the downsides of old fashioned technology.. The gizmos do at least offer better mpg, usually. Still can't have everything eh.
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
And you worry? I was chatting to Martyn Webb at Prescott on Saturday - reckons he doesn't bet much more than 14mpg from his Healey - admittedly it's completion spec and on triple carbs...
