8 members (Ian Wegg, AlyMatt, gaston, Alistair, Robbie, BobtheTrain, sprinty, B3MOG), 271 guests, and 26 robots.
+8Rich 92
Topics49,837
Posts837,287
Page 5 of 20 1 2 3 4 5 6 7 19 20
RedThree #405298 05/11/16 07:26 PM
Fantastic Calum, me fronts come 14 clicks rear 10 clicks. preload looks very similar, test drive tomorrow! the rears look like the turned into major strip out. i'll take seats out see the easiest option . May have to remove that pesky cross member didn't want to clamber around underneath only on a jack! saftey first !!!!!
skullmog #405299 05/11/16 07:29 PM
ps lend us your internal callipers...haha
skullmog #405304 05/11/16 07:33 PM
No problem...just drop by! laugh2
skullmog #405306 05/11/16 07:41 PM
on my way be there by tuesday rofl
skullmog #405314 05/11/16 08:28 PM
Good lord what is that shelf of grime?!?! laugh
I see now why you go by skullmog though. Makes me wonder if anyone has polished the bevel box in order to aid cleaning.
You can do it! Look forward to more shots.
skullmog #405316 05/11/16 08:36 PM
think the shelf of grime as you call it mr greenteagod is in fact the rear swing arm.
where all the road crap falls ,only done 2000 miles .got to get a full mudgaurd.
me thinks!!
skullmog #405388 06/11/16 09:31 AM
I too was frustrated by the fact every time I needed to get to the axle nut I had to drop the rear swing arm, but no longer. Last week at a car boot sale I managed to pick up a new 36mm combi spanner about 15" long.
That coupled with a 24mm socket and strong bar I should now be able to adjust wheel alignment and belt tension without jacking the rear end up.
Dab of oppo #405438 06/11/16 01:41 PM
FANTASTIC 36mm spanner cost about 60 quid off snap on.
skullmog #405441 06/11/16 01:45 PM
By the way only front olins fitted. what a difference.smoother more compliant more of what we need.every body go selll your grannies and buy these bad boys.... you may notice i like them a bit drive
skullmog #405472 06/11/16 03:57 PM
Get EMPIS 36mm rear axle wrench made for old VWs.
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
