Hi all.
I am hoping that someone might know about the injection fuel system as used in the present plus four I have had to disconnect the pipes at the rear and stupidly did not mark them thinking they would naturally fall back into place unfortunately they don’t. So if there is anyone out there that knows and could kindly check my thinking I would be very grateful. Here goes. There are two pipes in the system one supply and one return. One pipe that I need to connect comes from what I assume is the pump, (black plastic box situated by the fuel filler) and this I assume goes to the fuel rail supplied engine end buy the pipe covered in silver. The return comes from engine end form small black box on the bulkhead which again I assume is the relieve valve this travels back to the tank via a T piece on top of the fuel tank which goes both to the tank red connector and to the fuel filter which in turn is connected to the fuel tank white connector. Am I right?
Thanks Steve.
