8 members (AMorgan, Luddite, stumog, JohnHarris, JMcL, TBM, Jon G4LJW, Joske Vermeule), 285 guests, and 103 robots.
+8Rich 78
Topics49,872
Posts837,686
Rudolf
Peter ,
Just for clarity's sake for our American friend, the top diagram is a dynamo , the bottom one is the starter motor, and part 27b is the solenoid.
Andy G
1999 +8 , Indigo Blue.
MOG 615 #407797 14/11/16 10:54 PM
Ah yes! Should have mentioned that. Actually I just wanted the solenoid. The parts explosion of the dynamo and starter motor is probably not much use to him. Unless perhaps he just needs to replace the brushes.
I suggest by-passing the earth/ground circuit by putting a jump lead between the engine block and the battery. This will diagnose/eliminate poor connections.
Replaced battery and putting in new soleniod
Thanks for all the advice very helpful
Let us know if that works.
hopefully that's it, not terrible because both solenoid and starter are 50 years old, I should just go ahead and do the starter now
Ray Offline
Do you kwow if you have the earlier or later starter motor? why i ask, the older ones can be problomatic to get spares for. Try to plan the rebuild in advance.
Problem solved after a lot of detective work needed new solenoid and the WR wire from ignition to solenoid was no good so I replaced it car runs like a charm now
Well done nice cheap fix thumbs.
