Topics49,868
Posts837,642
Posts: 5,587 |
Could this mean something may drop off when one is going to the shops to get some milk etc ?
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
Better keep below 30 for a while until it's sorted.
Posts: 5,587 |
Better keep below 30 for a while until it's sorted. Dave , thats going to be very difficult !
Posts: 861 |
Its to remove the ARB - it ruins the car's ability to manage mid-corner apex bumps.
2010 Aero Supersport | 2017 VW Multivan | 1996 BMW M3 Evo
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Could this mean something may drop off when one is going to the shops to get some milk etc ? Quite possibly so I would take the Plus 8 instead of walking round on your own
Posts: 412 |
What exactly is the problem with the suspension ? They can't find it....
'di te incolumem custodiant'
Posts: 5,587 |
Posts: 1,400 Likes: 258
formerly known as Hugh Jorgan Has a lot to Say!
Posts: 1,400 Likes: 258 |
A quality issue at Morgan……… That's a surprise.
What exactly is the problem with the suspension ? That it wasn't designed in 1909
Posts: 3,838 Likes: 9
le Asbo du Bling Talk Morgan Addict
Posts: 3,838 Likes: 9 |
I made a call this afternoon to get some understanding of what the recall was about.
Firstly its not a recall as such Morgan has identified and been working on a number of improvements based on feedback from early owners and they have decided to make a number of changes based on this.
The HVAC system has been identified as requiring some modification as I understand it is not reaching the upper and lower temperature ranges so needs a modification. I believe that this may require some re-routing of the plumbing so is best dealt with by MMC rather than the dealers.
While dealing with this the factory have planned to undertake a software update which will for example open the boot from the key fob. Mine won't do this at present which can be a PITA.
In addition to all of this some changes are also being made to the suspension with up-dates to bushes and other suspension components being done.
I believe that after the issues with the 3 wheeler Morgan have decided to adopt a more proactive approach to problem solving for the new aero.
Mine is going to be get booked in sometime before Christmas and I'll post an update when this happens.
Slowly going green
