Topics49,871
Posts837,679
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
Peter ,
Just for clarity's sake for our American friend, the top diagram is a dynamo , the bottom one is the starter motor, and part 27b is the solenoid.
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Ah yes! Should have mentioned that. Actually I just wanted the solenoid. The parts explosion of the dynamo and starter motor is probably not much use to him. Unless perhaps he just needs to replace the brushes.
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
I suggest by-passing the earth/ground circuit by putting a jump lead between the engine block and the battery. This will diagnose/eliminate poor connections.
Posts: 121 |
Replaced battery and putting in new soleniod
Posts: 121 |
Thanks for all the advice very helpful
Let us know if that works.
Posts: 121 |
hopefully that's it, not terrible because both solenoid and starter are 50 years old, I should just go ahead and do the starter now
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Do you kwow if you have the earlier or later starter motor? why i ask, the older ones can be problomatic to get spares for. Try to plan the rebuild in advance.
Posts: 121 |
Problem solved after a lot of detective work needed new solenoid and the WR wire from ignition to solenoid was no good so I replaced it car runs like a charm now
Posts: 37,436 Likes: 982
Posts: 37,436 Likes: 982 |
Well done nice cheap fix  .
