6 members (Black Adder, Hamwich, +8Rich, Bishmog, Joe Speetjens, lord-richfield), 310 guests, and 49 robots.
John V6 68
+8Rich 65
DaveW 64
9,208 Registered Users
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,347
Posts813,062
Captain Morgan, IRWIN
Page 8 of 11 1 2 6 7 8 9 10 11
For a similar problem with engine light after a fix it came on again on the way home. With agreement I ran it for 2 months waiting for other parts to arrive. It eventually turned out to be an ECU problem & it was changed under warranty.
Tim
What is the part number for a new ecu? Is SS the best source or Morgan?
2000 G500, UNIMOG 1550L37 DoKa, M3W
I am attempting to run the pro tune program for the first time on my M3W to see what engine code was on recently. I can not seem to get the ecm to communicate with the pc. It says it can't find the driver for the ecm. My windows machine has run a search on line and on the compressor with no luck. Has anyone ran into this issue?
Hm, this is strange. I have not seen this constellation as long as you are connecting the computer and ECU directly via a standard USB cable.
If you are using a special cable you might have to install a driver.
I would recommend to unplug everything, then checking the windows device manager and see if you might have some missing drivers for your computer in general.
M3W willow green,Triumph T100,KTM LC4 Adv./Freer.250R, RD250/RS125DX, Alpine A110
Kurt
Hmm, ok. Maybe I'll try an other cable and maybe even an other computer. I am borrowing this PC as I am a Mac guy. My limited windows knowledge is based on a few generations back, this current OS is hard to figure out.
I used Windows 10 when I tried it, but didn't run into the problem. What year is your M3W. Has the tuning software changed since 2012?
It is a 2013 (I know I have it listed as a 2012 on the for sale section, that is a miss print)
Got a p0173 code today! Damn thing! Im going to put better gas in it and see if that helps
kirkusblog.com
1952 Ford 8N
Well I fixed it! I put in fresh plugs then gave it the beans down the highway. After about 20 minutes the light went out and stayed out.
kirkusblog.com
1952 Ford 8N
What fuel were you using? Brand and grade/octane rating please.
