5 members (Montegue, bmgermany, teknome, DPEvans, jbk), 281 guests, and 93 robots.
Sagging Hood
Topics49,859
Posts837,481
#408673 18/11/16 11:41 AM
My May 2015 M3W has used a litre of oil in 1500 miles, i do have minor oil leaks which i shall get rectified under warranty but not enough to effect this figure, wondered what others have experienced?.
0000oooooooo
Have put a total of a litre in mine in nearly 4500 miles, bearing in mind there have been two oil changes as well. Most of it was needed during first 2000 mile break-in period as to be expected.
Mine uses about a litre per 3,000 miles so normally doesn't require any top up between services.
Red Leader drive
Chris99 #408694 18/11/16 02:06 PM
The same. Level in the tank doesn't seem to drop at all.
Used about 1/2 ltr in 2300miles .looking at these posts seems normal....
I added a liter after 4000km. (i.e.2500miles)
(free breathing engine with stage 1 kit.)
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
Î dont put oil between each services (17000 miles)
Only once have I had to put much oil in at one go. At around 4200 miles after a 400 mile dual carriage way & motorway run it needed 800ml. Returning at lower speed due to rain very heavy at times it only needed a drop. Otherwise it occasionally needs maybe 200ml not enough to log or stay in the memory. I'm on 9200 now.
Tim
Mine does not use ant oil between services.
Almost 32,000 miles and I have never had to add oil between changes. A good thing to remember is that we are carrying 6 quarts instead of the usual 4 that bikes carry.
