1 members (+8Rich),
181
73
Topics49,861
Posts837,542
Posts: 86 |
My May 2015 M3W has used a litre of oil in 1500 miles, i do have minor oil leaks which i shall get rectified under warranty but not enough to effect this figure, wondered what others have experienced?.
0000oooooooo
Posts: 8,676 Likes: 411
Posts: 8,676 Likes: 411 |
Have put a total of a litre in mine in nearly 4500 miles, bearing in mind there have been two oil changes as well. Most of it was needed during first 2000 mile break-in period as to be expected.
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
Mine uses about a litre per 3,000 miles so normally doesn't require any top up between services.
Red Leader
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
Mine uses about a litre per 3,000 miles so normally doesn't require any top up between services. The same. Level in the tank doesn't seem to drop at all.
Posts: 1,544 Likes: 1
Posts: 1,544 Likes: 1 |
Used about 1/2 ltr in 2300miles .looking at these posts seems normal....
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
I added a liter after 4000km. (i.e.2500miles) (free breathing engine with stage 1 kit.)
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
Î dont put oil between each services (17000 miles)
Posts: 1,947 |
Only once have I had to put much oil in at one go. At around 4200 miles after a 400 mile dual carriage way & motorway run it needed 800ml. Returning at lower speed due to rain very heavy at times it only needed a drop. Otherwise it occasionally needs maybe 200ml not enough to log or stay in the memory. I'm on 9200 now.
Tim
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
Mine does not use ant oil between services.
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
Almost 32,000 miles and I have never had to add oil between changes. A good thing to remember is that we are carrying 6 quarts instead of the usual 4 that bikes carry.
