1 members (sprinty), 279 guests, and 58 robots.
Topics49,860
Posts837,486
Jonny72
Page 76 of 108 1 2 74 75 76 77 78 107 108
Draggin Offline OP
Recently when starting there has been a squeal coming from the front. Maybe this contamination on the idlers is to blame? I cleaned them with some acetone, and we shall see!
kirkusblog.com
1952 Ford 8N
Originally Posted By Draggin
More of the Jap cover installation, I did space ip the Cooling Kit Vent by installing some washers under the spacer tubes, but not it lays tight against the bottom of the radiator cowl....
Sounds like the answer may be to shave away some material from the underside of heat shield.
Draggin Offline OP
Yes i think so too!
kirkusblog.com
1952 Ford 8N
Draggin Offline OP
Im just not sure how to trim the scoop part...
kirkusblog.com
1952 Ford 8N
Draggin Offline OP
Bad news, the squealing goes away when the clutch is pressed in....
kirkusblog.com
1952 Ford 8N
Could be worse...could be MY car making noises and leaking oil!
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
Draggin Offline OP
Ouch Ken!
kirkusblog.com
1952 Ford 8N
That is odd, perhaps too much crank end play for some reason? Could be a thrust bearing I suppose, causing a cam pulley to rub? Are you sure noise is from the cam drive area?
I believe it's polycarbonate so suggest just carefully filing away material underneath, around the point of contact with rocker covers.
If you're thinking that the pressure of the pedal against the clutch pressure plate is moving the crank, it "should" have no effect on the noise other than possible allowing for a very slight rpm difference without the trans turning.
The hub adapter for the flywheel/clutch is independent and supported by it's own bearing. Also the Centa is not longitudinally connected in the middle. So no forward/back motion of the crank can take place with the press/release of the clutch.
Kirk,
I would get a long screwdriver and use it as a stethoscope while it's running or pick up a cheapie from a parts store or Harbor Freight. If you place the handle end on your and "ground" it out hard in your ear, you can pick up a lot of noises in lieu of actually having a stethoscope. I have a cheap stethoscope and it works good, but the ear pieces are not comfortable for a long period of time.
Does it make the noise while driving? Or just at idle sitting still?
Dan
