7 members (Bitsobrits, DCH, B3MOG, JohnHarris, Barry M, tezzer, linklaw),
346
82
Topics49,848
Posts837,404
Posts: 4 |
Good evening, would anyone know what the yellow padlock warning light means on my 2014 +4 Dashboard. Surprisingly it is the one light not described in the handbook! Genius  Thank you
if it was put together by hand I can repair it.
+4 x 2
Posts: 12,257 Likes: 317
Posts: 12,257 Likes: 317 |
Posts: 5,439 Likes: 131
Black Rat Charter Member
Posts: 5,439 Likes: 131 |
That's a new one on me A Google search suggests it's an electronic steering wheel lock warning and the steering wheel needs to be moved slightly to release. Best I can do
Posts: 3,643 |
Just a guess, immobiliser problem. Try a different key to see if the light goes out.
......Beaten to it
Posts: 2,779 Likes: 5
Posts: 2,779 Likes: 5 |
Unlock the garage door before you drive out?  I would think immobiliser circuit too..
Posts: 932 Likes: 11
Posts: 932 Likes: 11 |
All (" modern" cars from the last 15 years) have an transponder in the key, it makes elektronik contact with the system so the key is not only an mechanical unit but also elektronik .... and if it fails .... you get somtimes an yellow padlock on the dach ..... but i dont now if it is also in an Morgan key ........ but ... Morgan +4 keys are from Ford ? and Ford had it for at least 15 years
Stefan 2001 4/4 AR 4 soon
Posts: 5 |
I have the same issue - flashing yellow padlock on my 2014 Plus 4. Everything works but this light now comes on when the key is out instead of the normal flashing immobiliser light - any ideas appreciated
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
Ditto. Don't worry about it.
Posts: 1,461 |
It means that you are exceeding the terms of your ASBO.
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
If it is a padlock on its own then it is normally to do with door locks - if it's a padlock on top of a car symbol then it's a passive anti theft system
