5 members (mickyb, asbojohn, Image, Luddite, Nickplus4), 393 guests, and 17 robots.
+8Rich 92
Posts837,284
Page 11 of 20 1 2 9 10 11 12 13 19 20
skullmog #411180 29/11/16 04:35 PM
Me too!
M3W, now!!!
skullmog #413128 05/12/16 09:17 PM
JVS Offline
I installed the front Ohlin's shocks and measured the spring before hand at 6 1/4"
http://i347.photobucket.com/albums/p448/jvs1/Ohlins%20off%20the%20ground_zpsk0o3mztj.jpg
and after the front end came down off the jack onto the ground with the weight of the front end on the shocks now, measurement is almost the same. sorry for the upside down picture.
http://i347.photobucket.com/albums/p448/jvs1/Ohlins%20on%20the%20ground_zps4gus1nmr.jpg
this would lead me to think that these springs are too stiff and not allowing the spring/shock package to work well together. Also the shock/spring is at a 45 degree angle which may not be ideal for the shocks to work well?
GoPro video test ride tomorrow so we can see how the shock/spring setup is working in real life conditions.
I think the rear shock/spring setup may also have the same issue of having too hard a spring?
I'll have more pictures tomorrow.
JV Sclafani
Boca Raton, FL
'13 M3W Metallic Orange Pearl
128CI Steered by Empire - Riding on Ohlins
skullmog #413131 05/12/16 09:42 PM
My front spring lengths are at 164mm at full droop (car jacked up andwheels off the deck) and 153.5mm with load on. Call it 6 7/16" and 6 1/16"
Photo shows the preload (sort of)
I'll have a look at exactly what springs I have in the morning. Don't know if we will have the same free length and rate of spring
RedThree #413263 06/12/16 02:09 PM
Had a look at my front springs, the spec is;
Ohlins 01095-49/130 L3414
Measured off the car but on the shock, length 164.4mm (6 1/2")
and measured off the shock, free length of 180.5mm (7 1/8")
Both measurements taken ground face to ground face and at the same point on the spring.
From some details I found on the web about Ohlins Springs the code means it is 180mm long with 57mm ID and a spring rate of 130N/mm (742lb/in)
skullmog #413292 06/12/16 03:38 PM
JVS Offline
Here is the spring with no weight on it:
Here is the spring with the weight of the machine on the front suspension
More later in the week
JV Sclafani
Boca Raton, FL
skullmog #413331 06/12/16 05:00 PM
JVS Offline
The string rate of 742 lbs I think is way too stiff.
Maybe a rating of 250 lbs for our M3W
Along with tge shocks mounted at a 45 degree angle?
Most applications are at a 20 degree angle so this maybe be part of the problem too.
I'll be talking with the ohlins tech later this week on getting an update spring to test.
JV Sclafani
Boca Raton, FL
skullmog #413358 06/12/16 06:20 PM
If I understand your measurements correctly, the spring/shock is "topped-out" with the static weight on the front? That would make for some very squirrelly handling I would think with no suspension droop available at all! The 45 degree angle and the leverage of that along with the location in-board from the spindle gives the suspension some mechanical advantage over the spring, but there is no way that it should be topped-out at static ride height.
skullmog #413367 06/12/16 06:36 PM
JVS, I too think I would back the pre-load off, the shocks really shouldn't be topped out with weight on them. From the measurements I'm running about 1/4" less pre-load than you are and have very supple suspension that certainly appears to be using full travel.
skullmog #413380 06/12/16 07:18 PM
JVS Offline
Yes, backing off the pro-load is something we'll try but the 750LBS spring is too stiff too.
JV Sclafani
Boca Raton, FL
RedThree #413429 06/12/16 09:25 PM
Good word supple! thats what the ride feel is supple!!!! drive
