2 members (Ian Wegg, Richardllll), 234 guests, and 43 robots.
Adam12 69
+8Rich 68
John V6 59
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,389
Members9,215
Rbt Aero8, Salmon, stevends
Page 1 of 4 1 2 3 4
#414364 11/12/16 11:14 AM
My problem came back car won't start I think I have a ground issue don't know where to start looking
2025 MG ZS EV aka Trigger
I think we might need a bit more info! I.e. Is the starter turning the engine over for a start? I suspect not if you think you have a ground issue?
Check the engine earth (ground) strap between the engine block and the chassis.
sorry 1965 plus4 2 seater
SteveT #414398 11/12/16 12:50 PM
when I jump the starter it turns when I turn the key it just clicks
battery ground ok engine ground can't find it I don't have a lift
The click sounds like the solenoid activating. That is a plus at least.
How are the wiring connections to the starter....not just the earth?
The fact the starter turns when "jumping" should mean it is ok and the problem is elsewhere.
How fast does the starter/ engine turn when jumped? Does the engine start up and run?
Have you checked ALL the earth connections? Battery to ground, starter to ground? Try a long jump lead direct from battery neg to starter mounting bolt. That bypasses your existing earths. Don't use thin wire!!! Connecte starter end first before battery end! If the bypass cures then it is an earth problem.
No cure suggests ignition switch or wiring issues.
sospan #414407 11/12/16 01:20 PM
car doesn't start when I jump starter just turns but it hasn't been started in a while I going to try the neg ground test now
sospan #414409 11/12/16 01:27 PM
neg test still nothing installing new ignition switch tomorrow, I think my kid might have kicked something under dash because the car went from good to bad immediately
Page 1 of 4 1 2 3 4
