10 members (Willowgreen320, stefan s, Nick55, deano, Dek, Gramrugby, ajsms999, 2949olivier, MJF, BLUE+4), 253 guests, and 121 robots.
+8Rich 78
Topics49,871
Posts837,677
Rudolf
Best way of taking rad out on Plus 4 is to take the cowl off, undo the tie rods and bottom mounts pull it out from the top.
Can't see why you'd upset the tracking if the locknuts are tight on the track rods ends and you've the proper splitter
You'll still find radiator repairers, most now do commercial radiators, heat exchangers and air con units.
Arwyn
BTW: I have no luck dropping the rad out the bottom. I remove the grill, loosen the rod that goes between the inner fenders, twist rad and pull out the front. Just need a little wiggle room between the innerfenders and wings.
Remember to ground the rad or else Your temp gauge will not work.
Button
Button #416768 22/12/16 01:58 PM
OOPS! Just read Arwyin's post. I also remove the cowl. I use allen head 10-24 bolts. It is easier to get a allen wrench in this tight area. In fact I braze allen wrench into bolt and use a 1/4" air wrench with a long extension. I just must remove the cowl too othen for one reason or another and this makes it very easy.
Button
Button #416769 22/12/16 02:01 PM
OOPS! Thanks Arwyn, I also take the cowl out.
Button
SimonH #416774 22/12/16 02:46 PM
what's the cost do I need to send you old one
Button #416775 22/12/16 02:47 PM
was planning on doing it this way
Private message sent
Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
The radiator will come out from below, and IF you have never taken the cowl off this may be the fastest method, but don't underestimate just how much height you need to be able to drop the radiator down below the car.
You also need a helper to catch it as you free its passage past the various obstructions (mainly the valences , the bottom "tray", the tie bar and the radiator mounting brackets)
If you have previously taken the cowl off and replaced the fasteners with quick release versions , it will probably be easier , and faster to take it out from above , and it can be done single handed this way.
Andy G
1999 +8 , Indigo Blue.
Well lubricated stainless steel fasteners (both on assembly and removal) and properly lined up fixing holes make the cowl removal and replacement a doddle.
When I rebuilt the 4/4 I spent quite a bit of time getting the cowl set up correctly so it could be easily removed and replaced before I painted the car.
Following on from Buttons suggestion. I used long 2BA stainless set screws with a hex head where space was limited so I could put a ring spanner on them, I used ordinary dome headed screws for the rest of the cowl
Arwyn
Arwyn
2BA????????? I use 10-24 Allen Head screws and nylock nuts. I braze a Allen Wrench into the Allen Head. Use 1/4" air ratchet wrench and very long extension. BTW: Cut the allen wrench so it does not stick up too far. With 3 Morgans I am constantly in one cowl or the other. This makes it easy - err easier.
Button
