10 members (Arwyn Williams, John Wilcox, AlyMatt, Plus Four Guy, jbk, Sir Percival, TalkMorgan, JohnHarris, Saxman1964, gomog),
218
35
Topics49,901
Posts838,046
Posts: 114 |
Gear-knob, that is... on a Ford Type 9 gearbox... how do I remove it? I've been gradually cleaning the interior and I think that the leather gearbox cover would be easier to clean out of teh car rather than deep in the footwell but I cannot see how to remove the gearknob to allow the gaitor to pass over the top. My knob has a standard-looking Ford knob and about one inch down from that is a metal elongated dome that seems to have a rubber joint with the main stick protruding from the gearbox.
Thanks
Neil 1988 Morgan 4/4 4 Seater, black 1996 LR Defender 110, white 2009 Honda Deauville, black
Posts: 2,568 Likes: 98
Posts: 2,568 Likes: 98 |
The stick it's self comes in 2 parts with the rubber joint. Ignore this, it won't come apart and if you do get it apart you've broken it...lol
The knob itself should just unscrew.... easy.
Posts: 114 |
Tried unscrewing tonight - anticlockwise - and it doesn't want to budge. It's just twisting up the rubber joint that I don't want to break. Can you suggest *how* I just unscrew
There is always the possibility of a previous owner super-gluing it in place as they were a bugger for coming loose.. which is really irritating.
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
Try using a hairdryer (not a V6) on the knob, the heat should break the joint, but cover the gaiter. Locktite should keep it firm on reassembly. If necessary wrap a few layers of masking tape round the stick, and hold with Mole Grips. Round jawed will work best.
