Topics48,364
Posts813,344
Members9,215
Posts: 1,578 Likes: 105
Posts: 1,578 Likes: 105 |
I once attended a demonstration of a water jet cutter which used nothing more than high pressure water to cut through a piece of 1 inch steel plate.
Arwyn
Posts: 21,871 Likes: 168
Posts: 21,871 Likes: 168 |
I might occasionally use a garden sprayer but I wouldn't use a pressure washer. It's a blunt instrument and can put water where it shouldn't be.
OK for cleaning concrete drives though.
Posts: 6,829 Likes: 59
Posts: 6,829 Likes: 59 |
OK for cleaning concrete drives though. And brickwork and patios and coping stones ....
Posts: 1,415 |
Arwyn Most water jet cutters use powdered Garnet as an abrasive, the water jet is just the medium that carries the Garnet to the workpiece. Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 26,760 Likes: 425
Posts: 26,760 Likes: 425 |
We installed in the early 80s a pressure jet cutter using veg oil to cut crunchie bars to shape (or at least the foamed sugar core). Before that the bars were cut from blocks with a band saw that caused a lot of waste. This waste was then used by Cadbury in Keynsham as Crunchie rework syrup once redisolved in sugar.
The new system meant far less waste so less CRS. The CRS had a strong flavor so we had then to create CRS to feed all the other lines like Turkish delight
Posts: 1,639 Likes: 20
Posts: 1,639 Likes: 20 |
OK for cleaning concrete drives though. And brickwork and patios and coping stones .... Not so sure! After  gets her hands on the power washer and is let loose in the garden I have all manner of repair work to deal with.
Roger 2011 Plus 4
Posts: 6,538 |
My  is like that too! Off she goes Blasting Lance at the fore - nothing in her path is safe!! And she has a strange smile on her face - quite a worry!! She was thrilled this week when I told her that the garden furniture would need doing too!
Neil
Posts: 11,868 Likes: 138
Posts: 11,868 Likes: 138 |
There's a familiar thread emerging here, Jane is equally enthusiastic at blasting crud off pretty much anything in sight with our pressure washer.
Posts: 5,232 Likes: 125
Posts: 5,232 Likes: 125 |
There's a familiar thread emerging here, Jane is equally enthusiastic at blasting crud off pretty much anything in sight with our pressure washer. Don't stand still for too long ....
OK for cleaning concrete drives though. And brickwork and patios and coping stones .... Not so sure! After  gets her hands on the power washer and is let loose in the garden I have all manner of repair work to deal with. At least the bad bits are found before they do any damage.
