4 members (Zach, IcePack, ScotiaSteve, thelastgizmo), 223 guests, and 30 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,147
stumog Offline OP
I wonder if anyone else has had a similar problem, on my ali, Rad, on my Roadster I had a small leak from the drain plug and when I went under the car to tighten it the plastic drain plug broke in two with half the plug still in the Rad, I will now remove the Rad, and drill out the old plastic plug, has anyone any ideas what to replace the plastic plug with ?
Morgan 2009 Roadster Rolls Royce Lush Green 3.0 V6
Audi A4 Advant (some blue colour not botherd)
Its an M10 x 1.5 thread
PM your contact details and I'll stick a new one in the post
Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Rog Offline
Mine uses a standard metric hex steel zinc plated bolt with copper washer. When it was new I coated it in PTFE grease before assembling. I took it out recently when I drained down to try a different stat and it was still bright with no sign of corrosion.
Roger
dmh Offline
Have heard of a number of catastrophic radiator failures when plastic fittings fail.
It seems the all aluminium option is best.
David H
I should have said, I use an M10 bolt with a reusable dowty washer, and not the plastic fitting
Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
stumog Offline OP
Andy Stuart
Bee Hive Cottage
1 Fleckney Road
Kilby
Leices LE18 3TB
Thanks for your help
