3 members (Alan Patterson, DCH, JoeSpeetjens), 178 guests, and 67 robots.
+8Rich 76
Topics49,860
Posts837,520
Jonny72
#430390 18/02/17 10:45 AM
Hi Everyone
i think the flasher unit on my 1997 4/4 is failing as sometimes the indicators work and sometimes they don't all fuses and bulbs okay.
I've looked at the flasher and it does not display a make or part number, only the following:
205
12.8v 85c/m
C:21...25w x 2 (4)
R:0...5w
A 880934 DOT
Does anyone know of an internet site i can order one from and what i need to order as i live quite a way from any Morgan dealers any advice greatly received
thanks
Trev
Try carbuildersolutions.
www.carbuildersolutions.com
Holden
www.holden.co.uk
You could also do a google search for the part you need.
Is it's earth OK?
doesn't appear to be earthed just in amongst a load of wires behind middle of dash
Originally Posted By Trev&Valmog
....i live quite a way from any Morgan dealers...
Where are you located in Kent? Try Brands Hatch Morgan - tel 01732 882017
Do all the lamps fail at the same time or just individual ones?
On my old 4/4 the rear nearside was a bit hit or miss due to a poor earth in the bulb holder. All other indicators were ok.
As for the flasher unit itself, take it out and clean the contacts. Check out this site too for a bit more info.
https://www.howacarworks.com/accessories/testing-and-replacing-a-flasher-unit
All lights on side will remain on when it stops or all lights on if i use hazards but no flashing have taken car out today and if i hit flasher unit whilst stalk is on when turning they work !!
A good link above thanks for that
Had a similar problem on my Tasmin many years ago.
Took relay can apart to find a broken solder joint on the circuit board. Repaired, but it didn't last long as the relay was fitted upside down. Eventually replaced the relay...
Is your relay sealed?
Yes a sealed unit
Not worth fiddling with, they are cheap as chips. Which might explain why they fail often!
