7 members (MartinB60, nick w, davewhite, RichardV6, DaveW, Alan Patterson, hugo),
203
58
Topics49,859
Posts837,507
Posts: 25 |
Hi Everyone i think the flasher unit on my 1997 4/4 is failing as sometimes the indicators work and sometimes they don't all fuses and bulbs okay. I've looked at the flasher and it does not display a make or part number, only the following:
205 12.8v 85c/m C:21...25w x 2 (4) R:0...5w A 880934 DOT
Does anyone know of an internet site i can order one from and what i need to order as i live quite a way from any Morgan dealers any advice greatly received
thanks Trev
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Try carbuildersolutions. www.carbuildersolutions.comHolden www.holden.co.ukYou could also do a google search for the part you need.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Richard 1976 4/4 4 Seater
Posts: 25 |
doesn't appear to be earthed just in amongst a load of wires behind middle of dash
Posts: 543 Likes: 2
Posts: 543 Likes: 2 |
....i live quite a way from any Morgan dealers...
Where are you located in Kent? Try Brands Hatch Morgan - tel 01732 882017
Do all the lamps fail at the same time or just individual ones? On my old 4/4 the rear nearside was a bit hit or miss due to a poor earth in the bulb holder. All other indicators were ok. As for the flasher unit itself, take it out and clean the contacts. Check out this site too for a bit more info. https://www.howacarworks.com/accessories/testing-and-replacing-a-flasher-unit
Posts: 25 |
All lights on side will remain on when it stops or all lights on if i use hazards but no flashing have taken car out today and if i hit flasher unit whilst stalk is on when turning they work !!
A good link above thanks for that
Posts: 28,899 Likes: 352
Posts: 28,899 Likes: 352 |
Had a similar problem on my Tasmin many years ago. Took relay can apart to find a broken solder joint on the circuit board. Repaired, but it didn't last long as the relay was fitted upside down. Eventually replaced the relay... Is your relay sealed?
Posts: 25 |
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
Not worth fiddling with, they are cheap as chips. Which might explain why they fail often!
