8 members (Rex_tulips , hugo , TBM , david nathan , Chris Cosher , Image , Dougie , MartinB60 ),
298
41
robots.
Admin ,
Global Mod ,
Topics48,364
Posts813,344
Members9,215
Most Online1,046Aug 24th, 2023
Has anyone found this on their cars? My front Bevel Box Mount is rubbing the inside of my Propshaft Cover.
Draggin` contact your dealer, it`s not right. It may need some remedial work doing to it.
Or I could file the sharp edge.
Hi Draggin Do you have another shot of where the NVH has hit the tunnel , so I can better understand where this is please? In understanding the work Phil Bleazey has done , we now know the box pivots vertically when under load. Wether this is a good thing is another matter. That showed the top of the box is quite capable of hitting the top of the rear bulkhead tunnel the box sits in , but where your rubbing contact area is much lower and I cant see how it would make a metal to metal contact if it swung upwards , or anyway come to that. Thanks Graham
I dont really have a good photo of it, but it is hitting the plastic inside of the driveshaft tunnel cover.
I would refer to dealer PDQ as advised above.
well its winter, so it will be a couple months before it is moving.
Mine started doing the same 20,000 miles ago, it's fine. It's the bolt that bolts the box to the mount - doesn't do any harm, just enjoy having fun in it!
Mine gives a bang if spirited gear change 1st to second!
