Morgan Aero 8
5 members (Morganmike, JoeSpeetjens, JMcL, +8Rich, ChrisConvertible), 228 guests, and 99 robots.
+8Rich 76
DaveW 52
Topics49,868
Posts837,636
Moggo
Hi Ashley
I'm taking it that you're not the Everton centre-half ?
Giles. Mogless in Paris.
pandy #434005 03/03/17 11:27 PM
Unfortunately not!
Peter J Offline OP
Formerly known as Aldermog
Good call Ashley!
The real challenge with the Plus 8 is that the exhaust tailpipe is about 18" behind the rear wheels. This means all the road crud is liberally splattered over the tailpipe!
Peter J #434088 04/03/17 11:32 AM
Smile, it confuses them
Sounds like a job for some neoprene ? Where's Dave when you need him.
Peter J #434095 04/03/17 11:49 AM
If a barrier can't be made, then the discerning owner would wipe down after every trip out with a moist rag. I prefer WD40 as a cheap wipe clean assistant on the exhaust.
I judge a man by the cut of his exhaust. It's like having perfectly shiny shoes...................
Peter J #434347 05/03/17 03:04 PM
The wheels on a trad also throw up crud onto the exhaust. Tar-like depisits are removed with tar remover, basically solvent softening of the tar that is then wiped off. Polishing is straight forward but some tight areas round the hangers.
Ashley.......what wax do you reccomend for hot exhausts?
Peter J #434348 05/03/17 03:06 PM
Isn't the exhaust hidden under the car? Why on earth do you need to clean it? hide
Jays #434378 05/03/17 04:43 PM
Its nice to have polished silencers and shiny stainless , I need to do this when I get a lift sorted !
madmax #434461 05/03/17 07:59 PM
SBM Offline
Blimey, you've changed..!! Dry weather Mog driver, polishing etc. What happened to using it, then..???
somestick
Jays #434493 05/03/17 10:27 PM
Same reason to have nice underpants and socks.
