9 members (Sir Percival, +8Rich, 1560, SteveT, How, verysideways, Mats, ScotiaSteve, Moggo),
347
56
Topics49,863
Posts837,565
Posts: 6,538 |
Excellent fix - good job!
Neil
Posts: 579 Likes: 5
Posts: 579 Likes: 5 |
12.03.2017, first ride of the year ...
in love with life. that's it.
Posts: 579 Likes: 5
Posts: 579 Likes: 5
hey, just quickly ... (don't have a manual with me now): what are the containers 1 and 2 for?  thanks! pete
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
hey, just quickly ... (don't have a manual with me now): what are the containers 1 and 2 for?  thanks! pete #1 is the brake and clutch fluid reservoir. #2 is the engine oil tank. Do I win a prize?
Posts: 902 |
Hi Comet, thats not your car. Have you bought another one? Whats different with the Aero screens.
Posts: 579 Likes: 5
hey Rocky, no no, its not mine, I just looked for a car online, with open front! ;-) Calum - thank you! #1 is the brake and clutch fluid reservoir. #2 is the engine oil tank. The brake and clutch stuff, I better don't touch, right? But with what kind of oil may I fill the engine oil tank? Pete
No problem The brake and clutch reservoir needs to be kept topped up to the level marked on it with DOT4 brake fluid (DOT 3 would be not be a problem, DOT5.1 is also good. Do not use DOT5 unless you really know what you are doing and are willing to completely clean out the system and make sure that all lines and seals are compatible with it!) The engine oil is 20W-50 V-twin oil, preferably synthetic at least once run in. I've been using Motul 7100 4T 20W-50 but others are available. I think in all but the early cars which have a small dipstick on the filler cap there is a level indicator built in to the tank itself; the level should be checked within a few minutes of stopping the engine not with it stone cold and been sitting for days.
Posts: 400 |
My mechanic refuses to put fully synthetic in mine. He means that any 20W50 four stroke oil, for motorcycles, will do. Added a liter of Castrol Power1 just yesterday, in fact. At the same time grease was added to the compensator, which is now quiet again.
M3W, now!!!
Posts: 579 Likes: 5
oh, so I can also add grease to compensator? I am at approx. 3500 km. Should I consider doing it?
Thanks Calum - will check for the oils you recommended :-) (I look forward seeing you in September!)
