Morgan Aero 8
1 members (TeddyAds), 244 guests, and 69 robots.
+8Rich 74
DaveW 52
Topics49,867
Posts837,615
Moggo
#432596 26/02/17 01:26 PM
Peter J Offline OP
Formerly known as Aldermog
There has been comment that the exhaust tailpipes on Tarka are not, how can I say this nicely, "grubby" and not in keeping with the rest of the car.
So, as it is raining outside I thought I'd wash and polish them, and perhaps consider a "DW" style" inner paint job.
First things first....cleaning.
Getting the muck off is easy, but the backed on road tar less so.
This is the result, first the near side:
And then the offside:
I thought about painting the inside black, but there is no obvious edge up to which one might mask, though it does look as if the inner was once painted.
To refinish properly it would be necessary to remove them, and as they are also the rear mounting point it is a job for a ramp. So for now they are staying as they are!
englandwave
Peter J #432597 26/02/17 01:28 PM
Phew!
DaveW can sleep again
Peter J #432612 26/02/17 03:13 PM
They look smaller in diameter to mine , not sure why they would be ?
madmax #432625 26/02/17 04:07 PM
Peter J Offline OP
3" OD.
Peter J #432627 26/02/17 04:22 PM
3" OD.
Optical illusion ! , 3 inches dia .
Peter J #432628 26/02/17 04:26 PM
These are the before shots I take it?
When do we get to see the finished results? stirpot somestick evil
Mark - No Longer driving
milligoon #432636 26/02/17 05:02 PM
Peter J Offline OP
OUCH!
When I get a powered buffing mop!
Peter J #432643 26/02/17 05:49 PM
I have a flexi driveshaft you could get a dremel like polisher on the insides if you wish to borrow it?
There again, it could be said, that you've removed the patina!
milligoon #432647 26/02/17 05:55 PM
Peter J Offline OP
Ill take you up on that.
The photos look better than the reality.
Peter J #433987 03/03/17 09:24 PM
http://www.ebay.co.uk/itm/Polishing-Foam-Sponge-Cone-Metal-Pad-Car-Wheel-Hub-Care-Polish-Buffing-130mm-/151993769733?hash=item236388df05:g:w4QAAOSw~OVWzW0A
You need one of these!
Once polished, it's a good idea to seal the exhaust tips with a heat-resistant sealant or wax to help keep them clean.
