8 members (John V6, MATTMOG, Neville1, +8Rich, Sir Percival, TalkMorgan, TBM, Ian Wegg),
226
84
Topics49,867
Posts837,624
Posts: 8,646 |
Hi Ashley
I'm taking it that you're not the Everton centre-half ?
Giles. Mogless in Paris.
Posts: 25 |
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Good call Ashley!
The real challenge with the Plus 8 is that the exhaust tailpipe is about 18" behind the rear wheels. This means all the road crud is liberally splattered over the tailpipe!
Posts: 11,531 Likes: 317
Posts: 11,531 Likes: 317 |
Sounds like a job for some neoprene ? Where's Dave when you need him.
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
If a barrier can't be made, then the discerning owner would wipe down after every trip out with a moist rag. I prefer WD40 as a cheap wipe clean assistant on the exhaust.
I judge a man by the cut of his exhaust. It's like having perfectly shiny shoes...................
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
The wheels on a trad also throw up crud onto the exhaust. Tar-like depisits are removed with tar remover, basically solvent softening of the tar that is then wiped off. Polishing is straight forward but some tight areas round the hangers. Ashley.......what wax do you reccomend for hot exhausts?
Posts: 14,009 |
Isn't the exhaust hidden under the car? Why on earth do you need to clean it?
Posts: 5,587 |
Isn't the exhaust hidden under the car? Why on earth do you need to clean it? Its nice to have polished silencers and shiny stainless , I need to do this when I get a lift sorted !
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Isn't the exhaust hidden under the car? Why on earth do you need to clean it? Its nice to have polished silencers and shiny stainless , I need to do this when I get a lift sorted ! Blimey, you've changed..!! Dry weather Mog driver, polishing etc. What happened to using it, then..???
Isn't the exhaust hidden under the car? Why on earth do you need to clean it? Same reason to have nice underpants and socks.
