Topics49,880
Posts837,776
Posts: 136 |
I notice some driveline movement when releasing the clutch during hard acceleration with my 57' +4. The engine mounts were recently replaced and the Moss tranny mounts seem to be good as I don't get any movement while rocking the driveshaft. Any thoughts as to what could be causing this?
1959 4/4 - sold 1957 +4 - sold 2017 M3W - sold
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
I notice some driveline movement when releasing the clutch during hard acceleration with my 57' +4. The engine mounts were recently replaced and the Moss tranny mounts seem to be good as I don't get any movement while rocking the driveshaft. Any thoughts as to what could be causing this? Hard acceleration ?
Posts: 136 |
I notice some driveline movement when releasing the clutch during hard acceleration with my 57' +4. The engine mounts were recently replaced and the Moss tranny mounts seem to be good as I don't get any movement while rocking the driveshaft. Anym thoughts as to what could be causing this? Hard acceleration ? Well as much as a stock 2 liter Triumph boat anchor will put out when shifting at 5K RPM.
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Check the the U bolts on the back axle,they are prone to snapping.Can cause all sorts of strange movement when the axle comes loose.
Posts: 37,443 Likes: 984
Posts: 37,443 Likes: 984 |
Are the UJ's on the prop shaft o.k. ?
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
How much backlash in the diff?
Posts: 136 |
U-joints are good and the axle backlash is within spec. I'll check the axle U bolts tomorrow when I can get underneath. Thanks everyone!
Posts: 1,149 Likes: 19
Posts: 1,149 Likes: 19 |
hi JFP we are rebuilding our 1958 plus 4 had to fit handbrake cable yesterday found soldering handbrake cable nipple didnt hold so tapped the nipple and clamped the cable with a bolt ...much better I now have issues such as the timing to consider as the new accuspark dizzy cant be timed statically ie set at tdc then advance vac advance knob half turn which is 4 degrees
so i guess i'll have to use the strobe and a running engine but set to how many degrees cause the dizzy weights will add some degrees
im guessing i need about 10 - 14 degrees advance?
Rob
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
Rob Won't an engine at a low idle be the same as static as the weights won't have kicked in any advance ?
Posts: 27,822 Likes: 750
Posts: 27,822 Likes: 750 |
Steve, that is how I remember it.
