2 members (Grumpy2, Bunny),
405
85
Topics49,859
Posts837,483
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
Well the MOG in at Richard Thorne big banging noise from rear when pulling away with gusto! Ok normally, thought might be belt but there mech says it's all tight! So he dropped oil out of BB all nice n clean no bits of metal or out else. So left it with them we wait for phone call☹️ You too? Hopefully they will solve yours then fix mine in a few weeks when it goes in for its annual!!!
Posts: 423 Likes: 2
Posts: 423 Likes: 2 |
Having reached the point where the noises have been minimized but not entirely removed. Am now at the place where if I don't hear something anymore then it either failed completely or is laying on the road somewhere behind me.
As for the original poster I would add that it could very well be the belt ratcheting, hopping a tooth, while lighting out quickly. I had this happen to me a few times in the early days but I have since stopped it as the belt runs on the looser side as well as the practice eats the rear tire quickly!
Punching it to make a point or win a quick scratch race is all well and good but I have gone through three rear tires and five sets of fronts due to hard aggressive driving. It gets expensive. How many miles on your car at this point?
Lance 1981 Plus 8 2016 Three Wheeler 2022 Corvette Stingray Convertible z51
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
Over 32,000. A lot of experience behind that number.
Posts: 1,544 Likes: 1
Posts: 1,544 Likes: 1 |
back from menders!!!! well Saturday mech says belt fine will have to investigate.....well today went to pick up ooh it was just the belt loose! Drive home all ok CONFUSED .COM
Posts: 1,338 |
Got down under! the belt like a bow string never been that tight ! i fear for the BB bearings..... has some free play but jeepers, will have to have a feel of another to compare. can't twist 20 deg let alone 90. must be ok because its adjusted by dealer!!!! i'll stop wittering on now........
Got down under! the belt like a bow string never been that tight ! i fear for the BB bearings..... has some free play but jeepers, will have to have a feel of another to compare. can't twist 20 deg let alone 90. must be ok because its adjusted by dealer!!!! i'll stop wittering on now........ Has the noise gone? Of course, if the BB is being re-engineered per the other post then you might not care about the longevity of the current unit's bearings. On the other hand I suspect tightening the belt was easier than Phil's solution...
Posts: 1,490 |
Got down under! the belt like a bow string never been that tight ! i fear for the BB bearings..... has some free play but jeepers, will have to have a feel of another to compare. can't twist 20 deg let alone 90. must be ok because its adjusted by dealer!!!! i'll stop wittering on now........ . That's how mine is. Very quiet BB.
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
All seems good no banging anymore. BB still howling as normal. should all be good (P.M.A.)
All seems good no banging anymore. BB still howling as normal. should all be good (P.M.A.) Good stuff! WIll ask RTCC to remove the slack in the drivebelt in mine then... thanks for the update.
