1 members (Saxonian),
161
88
Topics49,847
Posts837,389
Posts: 31 |
Another good one that's readily available in the USA and probably available elsewhere is Plexus Plastic Cleaner Protectant Polish. Originally developed for use in the aviation industry and has good reviews.
Rob
‘61 Plus 4
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
And just to add a very cheap and readily available alternative......Bikers, when cleaning plastic visors often use toothpaste....start with lots of water in the mix just to be sure but there is no way it should scratch. I once caught my visor on a hotel door frame and there was even paint transferred onto it, all cleaned off with a few minutes with toothpaste and tissue paper (loo roll).
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
I have used a very fine Autofinesse polish. Last year I polished the sidescreen windows with Autofiness fine polish as used for the final buffing of the paint. It did a good job. Some of the "whitening" toothpastes are ok too. Very fine polishing effect. A paste made from Sodium bicarbonate is handy. Again a fine polish effect. Good for tea stains inside mugs! It brings back memories of preparing metal samples for microscope viewing. We usually finished them with 10micron diamond paste on polishing wheels. Softer metals were tougher to polush than hard in many cases.
Posts: 363 |
And just to add a very cheap and readily available alternative......Bikers, when cleaning plastic visors often use toothpaste....start with lots of water in the mix just to be sure but there is no way it should scratch. I once caught my visor on a hotel door frame and there was even paint transferred onto it, all cleaned off with a few minutes with toothpaste and tissue paper (loo roll). Toothpaste is also really helpful for cleaning glasses (spectacles) - polishes surface marks off without being abrasive enough to change the optical qualities of the prescription lenses!
Doug 1985 4/4 4str, Jubilee Blue
Posts: 2,583 |
Meguiar`s Plast RX is good and restores yellowed/scuffed plastics hard & soft.
Posts: 327 |
Just as an aside, when i drop my soft top i place a soft towel where the 2 faces of the rear plastic window would otherwise contact as the hood folds. After several years of putting up with a scratch line across the centre of the window on various drop tops this seems to help prevent the problem.
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Just as an aside, when i drop my soft top i place a soft towel where the 2 faces of the rear plastic window would otherwise contact as the hood folds. After several years of putting up with a scratch line across the centre of the window on various drop tops this seems to help prevent the problem. That's exactly what I do as well
Posts: 228 |
Are there any products which will remove or at least improve scratches in the clear plastic?
The hood to my car came with a nasty one.
Andy
2011, 4/4, 2.0, 75th Anniversary 2016, VW Polo GTI 2012, BMW 520d Touring
Posts: 318 |
Hi
I also used the Meguiar`s Plast RX yesterday - It worked a treat and best applied with a microfibre foam pad
Gajet
2013 Plus 8 Aero S5 Build week 11
Posts: 398 |
Thanks to everyone that responded to my request for information.
I have an embarassment of riches in all the responses - you are a generous, knowledgeable lot!
I will start auditioning for a young slim person....! Condor
Oct 13 build 4/4
