1 members (JohnMat),
267
103
Topics49,869
Posts837,666
Posts: 41 |
I completed the installation of the fuel tank plate yesterday. I had a local sheet metal shop produce the plate. My preference would have been for aluminum (or aluminium), but they said that would crack at the bend for the flange. Consequently, I specified stainless steel. The vertical portion measures 9" square and the top flange is 2" x 9". Thickness is 0.25", so it's very strong and weighs (I'm guessing) 3-4 lbs. It is bonded to the tank with silicone adhesive.
Dan
'70 Morgan +8 '65 Fiat Moretti 1500 '03 "hot rodded" Toyota Camry 5-speed
Posts: 3,727 |
Looks a nice job, Dan. So hopefully you will sleep better in the knowledge that you have de risked that dodgy weakness.
Posts: 28,904 Likes: 352
Posts: 28,904 Likes: 352 |
Think I will look into doing something similar on RTA. Looks a neat job Dan!  Cheers,
Posts: 453 |
What was the problem with the tank?
H3
Posts: 41 |
What was the problem with the tank? On older cars like mine, a rear-end collision and consequent forward movement of the fuel tank can cause it to be pierced by the handbrake mechanism (see photos). The plate is there as a reinforcement to prevent this from happening.
Dan
Posts: 453 |
What was the problem with the tank? On older cars like mine, a rear-end collision and consequent forward movement of the fuel tank can cause it to be pierced by the handbrake mechanism (see photos). The plate is there as a reinforcement to prevent this from happening. [Humour: ON] But, with "an old car like yours", the rear end colision shouldn't be a issue, as the car which is following has better brakes! [/Humour: OFF] (more seriously, in the case of a rear-end colision with a 2 tons modern vehicle the possible hole in your tank will not be the worse of your problems regarding the body work...)
H3
It could well be, with proximity to hot exhausts, sparking electrics etc... Cheers,
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
Can I suggest you go like hell - and then worry about the front end.
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
