7 members (Gordon D, Simon, Montegue, GrumpyPa, TalkMorgan, Craig Jezz, TBM), 496 guests, and 143 robots.
Sagging Hood
Topics49,859
Posts837,479
#439895 30/03/17 04:22 PM
Pmh44 Offline OP
Hi everyone, just got around to fitting my badge bar. The problem is the clips that came with the bar don't want to tighten enough to stop the badge moving. Bar and clips bought from heart of england
Pmh44 #439904 30/03/17 05:04 PM
Suggest you measure the OD of your badge bar, then ask HoE for the correct size. Or when you have measured the OD, Google "badge bar clips". There are lots about and sizes are stated.
Pmh44 #439916 30/03/17 05:24 PM
Pmh44 Offline OP
Thanks Steve, I was assuming they would supply the right size as I bought them together.will give em a ring. Cheers. Paul.
Pmh44 #440044 31/03/17 08:21 AM
GaB
Unregistered
GaB
Unregistered
I fund the same problem with clips - and I thought they would all work.
I bought some from MSCC, but they were no good.
However, I found a decent gauge and diameter from Melvyn Rutter that works for me.
Pmh44 #440077 31/03/17 10:55 AM
At the risk of being utterly predictable........
A rubber wrap around the bar will do a visually satisfactory job. I'm saying hard rubber if there's enough space for one full wrap around.
If not, high density neoprene has the squash ability to do the job. It may need double sided tape to fix in position.
Pmh44 #440515 02/04/17 07:25 PM
Pmh44 Offline OP
Thanks chaps, problem solved, t-rex tape from b&q, one small piece wrapped around badge bar. One layer thick gives enough grip between the bar and clip. Happy days, now to find a centenary badge. Cheers paul.
Pmh44 #440523 02/04/17 08:09 PM
Centenary badges available here:
https://www.morgan-spares.com/accessories.html
Pmh44 #440548 02/04/17 09:51 PM
Originally Posted By Pmh44
t-rex tape from b&q
I've got a T-Rex LP but no tapes.
Best Regards
Lang may yer lum reek
t-rex tape from b&q
laugh2 sharp tonight Bob!
Pmh44 #589193 09/08/19 08:55 PM
Dear All
Does anyone know where I can buy a non standard badge bar clip with the centre of the holes 1.125” ( 28.5 mm) apart.
I was lucky enough to take part in last years “Drive to Victory”, to commemorate the end of WW1. Unfortunately, I have been unable to fit the commemorative badge to my Badge Bar because the distance between hole centres is bigger that the normal elongated extreme of slotted badge clips. Opening out the slots would not be practicable as doing so would weaken the the edge of the clip.
Any info would be very gratefully received.
With very best wishes
The Impaler
P.S. Have just exchanged my 4/4 T 3 MOG for a 2009 Plus 4 JV 09 MOG. Still suffering from a mega dose of euphoria.
