0 members (),
267
46
Topics49,844
Posts837,360
Posts: 288 |
Agreed that with a correct Suplex setup you should get rid of the nodding, but IME the system needed a few hundred miles and a couple of adjustment sessions to settle down properly.
Now I can drive hands-off down bumpy pot-holed 'B' roads at 50mph with no problem whatsoever, so it's worth persevering to get the setup just right. great advice and as you said perseverance really worth it to get it just right ,for already the overall feel is so promising. SteveH and Harry
Stingmog
Posts: 1,103 Likes: 17
Posts: 1,103 Likes: 17 |
Glenn, What is the Avo / Mullbery version you mention?
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Will, have a look in Gomog for suspension details. A link to Mullberry is in the bespoke parts section. AVO supplied shocks developed by Rutherford Engineering for Morgans. Tim Ayres now sells them. I fitted them on my car last year if you remember. Rutherford developed the rear suspension hoop that Morgan went on to use. Peter Mulberry developed independant front suspension and sells via Mulfab. Peter Ballard developed the Suplex systems ( front and rear) that are the latest options.
GaB
Unregistered
GaB
Unregistered
Flyfisher,
As detailed above by Sospan. They are a long-standing alternative to Suplex, and made in Britain (not sure about the source for Suplex). I was expecting Suplex but was supplied with AVO, as the supplier has had quality issues with the adjustment point (breaking off)...
Posts: 1,418 |
Hi Steve.
Suplex cured my nodding straight away. 70,000 miles later and still no nodding, so once you've got it finally adjusted, you should be beaming from ear to ear.
Jeremy
2009 4/4 Sport Green
And nothing else !
Posts: 288 |
Hi Steve.
Suplex cured my nodding straight away. 70,000 miles later and still no nodding, so once you've got it finally adjusted, you should be beaming from ear to ear. . Thanks for that encouragement, we have now done about 200 miles and the nodding is improving. The strangest thing about this is the fact we had no nodding with the standard factory set up. MMMMM.. we will give it a few more miles and then return to Williams for some adjustment.
Stingmog
GaB
Unregistered
GaB
Unregistered
I have only done around 100-200 miles since upgrading (not Suplex). There was some nodding at first, but it is settling down well. I am no longer frightened of potholes! Oh, and the steering bearings have made a hell of a difference to the previous arm-wrenching low speed manoeuvring games. Not sure of any difference with brake reaction stays, but it all helps. Money well spent!
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
If it is settling down the only thing that I can think is that there is a little stiction in the new kingpins and bushes which is causing the effect, and that as they "run in" the suspension is starting to work as it should.
Certainly not something that I have experienced but perhaps my new bushes were not so tight on the kingpins.
GaB
Unregistered
GaB
Unregistered
I have had new hard chrome king pins and phosphor bronze bushes to replace the old plastic Devol bushes. Thanks for the heads up on some likely stiction until it all settles much more over the next 1000 miles.
