2 members (marshalben, JMcL),
97
114
Topics49,872
Posts837,695
Posts: 851 |
nice chrome mags and low profile tyres are all you need, forget the wires, they are only for posing and country lanes with a blond in the passenger seat naked
Posts: 3,439 Likes: 7
Goodwood Drifter Talk Morgan Addict
Posts: 3,439 Likes: 7 |
nice chrome mags and low profile tyres are all you need, forget the wires, they are only for posing and country lanes with a blond in the passenger seat naked a candidate for MissBelgium2008 applied for a student-job yesterday, beautifull face  better than blonds
Steven sold: M3W, Aeromax,V6, 4/4 4seater now: +fourLM62
my indicators don't work, and dealer started searching himselve as his mechanic (electrician????) couldn't find it hope it gets fixed by tomorrow, need the car for another RING-trippy on sunday (an AMG is waiting to be tested there...sadly no SLS)
Posts: 7,933 Likes: 133
Posts: 7,933 Likes: 133 |
Steven, the battery hasn't run flat has it?
I loose my indicators if the battery runs flat and it necessitates resetting the ECU to clear it.
And the photo above is excellent - I'd gladly have that as my desktop image.
Posts: 851 |
thanks for the stickers Simon.
hmm, gona tell my dealer to reset ECU but batt was not flat
hmm, gona tell my dealer to reset ECU but batt was not flat I'm not sure if the Roadster is the same as the Aero but there is a kill switch inside the engine compartment, which you can press to disconnect the power to the car/ECU. Leaving it off for 5-minutes resets the ECU - usually you can then push the switch back in, start the car and everything is (fingers crossed!) fine.
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
There was a story on Mogtalk last year where the PCB behind the dash switches - which apparently includes the flashing function - had failed and had to be replaced at some alarming cost. Lets hope it's not that then.
There was a story on Mogtalk last year where the PCB behind the dash switches - which apparently includes the flashing function - had failed and had to be replaced at some alarming cost. Lets hope it's not that then. got a call, it is fixed, what it was: dunno, but will post, it's under waranty (or I destroy the AeroSS on display this sunday)
indicator-problem: worn wire in fusebox new problemfront-left wing thouches the bumperette-arm going underneath it, tried fixing it with the 2 bolts on which the arm is fixed on a chassis-tube: didn't help, wing will be damaged....slightly, but it's more the uncomfable feeling of hearing them touch  also: I CAN'T DRIVEnormal .BE-morgan-driver: 70.000km with brake-pads me: 18.500km, front-right ones: only a "peel" was left  the new once are race-pads, will bite more instantly, but wear even more after service: engine feels so much better!!!!!
