8 members (ChrisConvertible, JohnHarris, Stephen888, JMcL, SEG, Alan Patterson, TBM, stumog), 207 guests, and 54 robots.
+8Rich 78
Topics49,871
Posts837,676
Rudolf
Page 15 of 18 1 2 13 14 15 16 17 18
nice chrome mags and low profile tyres are all you need, forget the wires, they are only for posing and country lanes with a blond in the passenger seat naked laugh2
1560 Offline OP
Goodwood Drifter
Goodwood Drifter
a candidate for MissBelgium2008 applied for a student-job yesterday, beautifull face laugh
better than blonds laugh2
Steven
now: +fourLM62
1560 Offline OP
Goodwood Drifter
Goodwood Drifter
my indicators don't work,
and dealer started searching himselve as his mechanic (electrician????) couldn't find it
hope it gets fixed by tomorrow, need the car for another RING-trippy on sunday
(an AMG is waiting to be tested there...sadly no SLS)
Steven
now: +fourLM62
Steven, the battery hasn't run flat has it?
I loose my indicators if the battery runs flat and it necessitates resetting the ECU to clear it.
And the photo above is excellent - I'd gladly have that as my desktop image.
thanks for the stickers Simon.
1560 Offline OP
Goodwood Drifter
Goodwood Drifter
hmm, gona tell my dealer to reset ECU
but batt was not flat ooo
Steven
now: +fourLM62
I'm not sure if the Roadster is the same as the Aero but there is a kill switch inside the engine compartment, which you can press to disconnect the power to the car/ECU.
Leaving it off for 5-minutes resets the ECU - usually you can then push the switch back in, start the car and everything is (fingers crossed!) fine.
There was a story on Mogtalk last year where the PCB behind the dash switches - which apparently includes the flashing function - had failed and had to be replaced at some alarming cost. Lets hope it's not that then. frown2
1560 Offline OP
Goodwood Drifter
Goodwood Drifter
got a call, it is fixed,
what it was: dunno, but will post,
it's under waranty (or I destroy the AeroSS on display this sunday) viking
Steven
now: +fourLM62
1560 Offline OP
Goodwood Drifter
Goodwood Drifter
indicator-problem: worn wire in fusebox
new problem
front-left wing thouches the bumperette-arm going underneath it,
tried fixing it with the 2 bolts on which the arm is fixed on a chassis-tube: didn't help,
wing will be damaged....slightly, but it's more the uncomfable feeling of hearing them touch frown
also: I CAN'T DRIVE
normal .BE-morgan-driver: 70.000km with brake-pads
me: 18.500km, front-right ones: only a "peel" was left shocked2
the new once are race-pads, will bite more instantly, but wear even more innocent
after service: engine feels so much better!!!!!
Steven
now: +fourLM62
