0 members (), 276 guests, and 43 robots.
+8Rich 94
Posts837,276
Page 1 of 5 1 2 3 4 5
Whenever my M3W rests for some time in the garage it takes quite long to get the engine fiering. Last time even the battery run flat.
To avoid a similar problem today I sprayed a little bit of starter spray to the filter before pushing the ignition button. My 3Wheeler has never ever started so perfectly before.
Has anyone else got a similar experience?
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
Only with the petrol lawn mower.
Martin (Deano)
- not used it myself but a neighbour had a can of start spray which is sold in Australia;it was called (I kid you not) -
"start yer bast*rd...."
made me chuckle laugh
James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
Check with protune the voltage throttle valve in the rest position it should be about 0.225 volt and look if the connector is not oxidizing, otherwise loosened both of the sensor to adjust the voltage and check that there is no air leakage.
Would not use that on a regular basis!!! I'm sure it puts massive extra load on piston tops, when we use it at work its very sparingly and only once i.e: if car been in storage for several years and we tried all other possibility....
Have you tried cycling the fuel pump?
Ignition on till pump cuts out, ignition off, repeat twice then try starting the engine.
Works for me.
Start ya Bastard is available in the U.K.! Same stuff as Easy Start, pure Ether!
Great for comatosing huge spiders in the garage. Starts engines too!
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Works for me.
That is exactly my standard starting procedure.
p.s.: I get a new starter battery tomorrow. Maybe that will support the starting procedure too.
Hannes
Works for me.
Thought it might be but also thought I should ask. smile
I'll just echo GLLOQ's suggestions in that case and maybe suggest fresh spark plugs. Best of luck finding the cause.
I find unless I have it connected to a battery conditioner between runs I get a prolonged start , with the conditioner it starts on the button ( most times ).
