2 members (yobtaf, BHV),
305
40
Topics49,860
Posts837,486
Posts: 12,257 Likes: 317
Posts: 12,257 Likes: 317 |
I am confused by this - my dealer described the sequence for hood fitting as
Install Hood - Rear before front Remove hood - Rear before front
It's all about avoiding pulling on the windscreen fixings ????
I agree that it's important to avoid stressing the windscreen, but I've never heard anyone advising securing the rear first. Are you sure you were listening carefully to your dealer, or is it possible you misunderstood what he was telling you in your excitement? Whether one has the Easy-up hood, the Trad hood, or a Simmonds hood, the procedure is the same - fix it at the front, then clip down the back. Similarly, when releasing you undo the rear first to take the tension off, then remove from the windscreen. It's the way I've always done it on my car (first with a traditional hood, now with a Simmonds) and in 17 years I've not had a problem.
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
There is a black round knob under the right hand side of the fascia, anyone know what this is? Cheers, Giles Sounds like the dimmer control for the instrument lights to me.
Posts: 1,615 Likes: 1
Posts: 1,615 Likes: 1 |
I have a trad hood. I suppose it could be that my dealer was standing on the passenger side when he showed me, and he mistook the back of the car for the front. Sounds plausible? I'm sure I was listening. Anyway, if this is the opinion of you all, everyone does
upwards- front first then rear downwards - rear first then front - I'll give that a go
SFG 2012 4/4 Sport
Posts: 3,824 Likes: 69
Posts: 3,824 Likes: 69 |
Thanks again, top forum is this! 👍🏻😃 who can tell me where the heater controls are, I've found the blower motor, but temp selection and distribution have evaded detection so far. I'm amazed to see and adjustable steering column! There is a black round knob under the right hand side of the fascia, anyone know what this is? Cheers, Giles Hi Giles - glad you are liking the car. Heater temp - is the other knob to the RHS of the fan. Can be reluctant when new. 5 clicks clockwise is max. Heater outlets - centrally under the dashboard x2, these are louvred so may be closed if you can't feel them working. They are directional if twisted, so you have a choice of cooking your knee, shin or ankle. I have 4 louvered outlets, 2 easily visible below dash and 2 more hidden further back in footwell. Nick
Posts: 28,899 Likes: 352
Posts: 28,899 Likes: 352 |
Tim, with an Easy-up, undo the two Tennax fasteners, one each side, before releasing the rear. Similarly they are the last to be fitted when putting the hood up.
Tim, with an Easy-up, undo the two Tennax fasteners, one each side, before releasing the rear. Similarly they are the last to be fitted when putting the hood up. Same as with a trad or simmonds hood. I count those as in the 'rear' group rather than in the 'windscreen' group.
Posts: 228 |
I'm sure I was advised to fasten the rear first on my trad hood. However I normally fix the rear press studs last, and vice verser.
I think I'd really struggle to do the rear inner fastens with the front in place first.
Need swivel pivots.......
Andy
2011, 4/4, 2.0, 75th Anniversary 2016, VW Polo GTI 2012, BMW 520d Touring
For trad hoods, especially in cold weather, I completely agree. They turn the exercise from a nightmare of straining and broken fingernails into a simple two-minute job. A marvellous idea.
Posts: 1,948 |
Tim, with an Easy-up, undo the two Tennax fasteners, one each side, before releasing the rear. Similarly they are the last to be fitted when putting the hood up. I also appreciate the reminder Graham, it's been so long since I used the hood - mainly because BHM showed me how to fold and stow it so neatly under the tonneau cover that I didn't want to disturb it. A few showers endured is a small price to pay for a neat cover - I always make it look like a pram!
Stuart "There's no skill substitute like cubic inches."
Posts: 3,696 Likes: 131
Posts: 3,696 Likes: 131 |
I agree that it's important to avoid stressing the windscreen, but I've never heard anyone advising securing the rear first... When I asked about this a few years ago, "rear first" was the consensus: Technique for fitting the hood? (1980 4/4). The handbook for my car agrees: Hood
When erecting the hood, always fix the eyelets in the back curtain over the turn- buttons first and then fix snaps across the top of the windscreen, making sure the sealing pipe runs along the back of the screen. If secured at the front first some strain will be necessary to pull the eyelets over the turn-buttons, which in time will pull away from the fabric.
However, it is recommended that if the hood is tight when dismantling it is advisable to release it at the turn-buttons, which avoids straining at the eyelets.
In reality I’ve found by far the best way is to get someone with younger muscles than mine to do it! My daughter’s fiancé can secure the thing in no time, in seemingly any order. ~iw
