New
Topics48,366
Posts813,390
Members9,215
Posts: 368 Likes: 1
Posts: 368 Likes: 1 |
I picked mine up from MorganWest in Santa Monica, freewayed it back to Pasadena and then over Angeles Crest Highway to home. It was terrifying and I would do it again in a heartbeat!! Drive it!
Posts: 909 Likes: 7
Posts: 909 Likes: 7 |
Check oil and brakes , and driving of course.....and pics of course.
Stefan
Posts: 1,774 Likes: 19
Posts: 1,774 Likes: 19 |
Drive it home! Do your own PDI before starting off and have a contingency / breakdown recovery plan. Choose a nice route. Stop for a break halfway to readjust clothing, ear plugs, helmet vs hat /goggles, sun cream, and any necessary driver servicing. When home, enjoy thinking what you would fix or change, and where you will drive next...
For helmets just use what you have already. See the helmet thread for what others use. ...
Posts: 638 |
Local dealership PDI would be essential for me - having had four MOG's.
David H
Posts: 1,670 |
Always do a walk around before setting off - that way you'll see if something's about to come detached before it does.
Posts: 99 |
Morgan of Morgantown West Virginia delivered mine on a chilly February day in an enclosed trailer. Brett the sales rep and his lovely wife then stayed for well over an hour going over the M3W! That was over a three hour delivery for them and he told me they have even delivered further. Your dealer should deliver it's not that far.
I had just bought a really nice lightweight aluminum trailer to go get it but Brett said no need we deliver! I needed a small trailer for my four wheeler, mower and to haul things around the house and shop anyway. Now I have a nice recovery trailer.
Now buy a set of Magnaflow Mufflers (see my post on this site) and let that engine breath better, run a lot cooler and just sound awesome!
High Noon Speed Shop
Posts: 1,490 |
Drive it. When you're on the highway part, vary between a little under the limit to ten over to vary the RPM, as well as changing up between 4th and 5th. That way your running ( not breaking) her in correctly. Do NOT lug her. That motor hates lugging. Nothing under 2,800 once you're rolling. 3,000-4,200 ish on this run. Like is said use the gearbox and right pedal to modulate in that range.
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
Posts: 508 Likes: 1
Dreiradschubser Talk Morgan Regular
Posts: 508 Likes: 1 |
Drive it, what ever happens, you will remember the rest of your life
Achim
Posts: 90 |
Will try to make that happen. At least first ride with go pro. Question, need to buy a few helmets . In the low desert in SoCal. ( like your weather ) 3/4 a good choice ? What do you use ? I have just been helmet shopping because my M3W should be here in a few weeks. I'm going with that Bell Pitt Boss helmet. It has an integrated pull down visor that I can use instead of goggles if I want. I'm also getting the additional clear visor and will swap it out with the tinted sun visor for an additional $10. The Pitt Boss is considered a half helmet but is DOT approved and comes with a zip off neck curtain for colder weather driving. It also has a dial system in the back to tighten it. So I can get a second helmet and use it for multiple people in case they have different head sizes. I tried on a lot of different helmets and this one is the most comfortable. And because it's a half helmet, it doesn't cut off my peripheral vision.
2017 Morgan 3 Wheeler -BRG Shark 2008 Lotus Elise California Edition -Red 2009 Land Rover LR2 -Black
Posts: 2,539 |
I suppose it really comes down to your risk tolerance level. Personally, if I was picking it up from a known dealer who had just gone over everything - from tire pressure to fluid checks - I'd be OK driving it.
However, assuming that right off-the-plane it's ready for a 120 mile drive is a bit of a bridge too far for me, unless you're going to take the time to thoroughly go over it in the parking lot at the airport... I have to agree there, my dealer had a few minor but important adjustments. Nothing major but i would definitely not drive it home without the dealer giving it the once over. As far as helmets I like my "Sir Stirling Moss Style" Helmet. I think there is nothing better to go with the car. Just this man's opinion!
