Morgan Aero 8
7 members (GrumpyPa, Deejay, Socalm3w, RichardV6, sezznowt, Pittsartist, Mike D), 360 guests, and 83 robots.
+8Rich 64
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,759
Please come and set off the MINI alarms at the new Cotswold stealership in Cheltenham grin2
Good idea. Gail tried to buy a mini from them in February. Very obnoxious and high brow. Worst mini dealer we have come across.
Martin (Deano)
Smile, it confuses them
Drive-by car alarming. One of my favourite sports in the Coupe !
Best score to date was in the Setanta Car Park in Dublin where I got a row of 7 in one hit. Great concrete bunker echo effect.
Alistair, you hooligan, I can't believe anyone would do this....
Works best in multi-story carparks, or try the thunderous sound effect in tunnels, especially low speed/ high gear... or so I've been told laugh2
Fellow Member of the side-exhaust hooligan owners club.
J. Neil
Originally Posted By Volvos60s60
I have tried to load pics without success. I tried following the idiots's guide but failed - not sure if a failure means I'm an idiot or not....
How to incorporate images in a message
First of all, you need to upload the image you have on your laptop in internet.
Go to www.postimage.org
Click choose images
In the pop up window, find the image on your laptop and Click open
Once the image has been uploaded, select all the web address next to the line: "direct link"
Copy it
Now the tricky part smile
In the talkmorgan message, when you are ready to insert the image do like this (REMOVE ALL * YOU SEE BELOW)
[*IMG]Paste*what*you*copied*before[/*IMG]
In other words: square bracket- type IMG-square bracket then the web address given by postimage square bracket-slash-type IMG-square bracket
Ta-da!!! Your pic is there!
I wonder what db rating one needs to set off car alarms ? Over 98db's ?
Hi Ale 72, thanks for the write up. Will give it a try tomorrow night when I get home
Ian
Yes the sidepipes certainly seem to be loud. I have no idea how the Coupe gets through an MOT. When under full load at high revs it is monumentally loud, it cannot possibly be fully legal.
Move on, nothing to see here, perfectly normal rofl
Impressive. I've got a Defender (AJ-V8 4.4 on twin sidepipes) that does the same, even when I'm not trying. The fact that the outlet location is higher up probably doesn't help.
Got very embarrassing when we used to have an apartment with a large communal underground car park - I became adept at coasting in quietly and lining up my space, but it was impossible to reverse out and leave without causing mayhem. In hindsight, that may be why some of the more stuck-up neighbours were a little cool towards us...
Stuart
thumbs
Serve them right for having defective or poorly installed alarm systems (and yes, I include manufacturers installations!) grin2
