6 members (Tresco, KennethM, DaveW, Morganmike, flyfisher, sezznowt), 277 guests, and 93 robots.
Sagging Hood
Topics49,859
Posts837,481
Page 88 of 108 1 2 86 87 88 89 90 107 108
Yes. Yes.
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
Draggin Offline OP
I installed the Australian Reversing Lamp today. Took about 2 hours.
kirkusblog.com
1952 Ford 8N
Interested to hear more - pictures maybe.
Did you fit to replace stock fog light?
Did you employ existing reversing light wiring?
If yes to above, do you have an intention for now redundant fog light switch?
Which white reversing light did you use/source?
Draggin Offline OP
Yes i fit it in the stock fog lamp spot, i used the existing fog lamp wireing for the sake of simplicity. I used the actual morgan part, the mounting and the wires hook right up. the price i got from the dealer was less than what i found it for online. Photos to follow!
kirkusblog.com
1952 Ford 8N
That's interesting. I would have expected if you used the MMC Australian spec. reversing light it would be wired with the same 4 way plug but with the two light cable connections picking up on the gearbox switched reversing light connections on the matching socket.
To better explain both the pair of wires for fog lamp and the reversing light are present and live on the wiring loom socket common to all variants. It's the matching plug on the LED light (whether it be fog or reversing) that determines which pair it hooks up to.
Draggin Offline OP
It comes without a plug, just two wires, so I wired it to the same 2 wires.
kirkusblog.com
1952 Ford 8N
Thanks for explanation. Surprised the plug appears to be added during build. Sounds like it would have been no more effort to wire to the dedicated cables though, as either way you would need to cut and remake wires to plug or socket. Further detail here
Draggin Offline OP
Pehaps if i had moved my 2 wires to the other 2 locations in the 4 contact plug, then it would work off of the trasmission switch? Im not currently curious enough to take out the 10 wood screws to find out.
kirkusblog.com
1952 Ford 8N
Draggin Offline OP
kirkusblog.com
1952 Ford 8N
Looks great, Draggin!
Aka Joejoe
