0 members (),
167
66
Posts837,931
Posts: 217 |
Hello all. Has anyone any experience with a sports exhaust on plus 4 gdi engine, Do they make a noticeable difference, I see from librands advert there is a small gain but is there anyone who has done it and is happy, also how does it sound, Thanks. Alan.
Posts: 27,830 Likes: 757
Posts: 27,830 Likes: 757 |
I had a Lirands on my Rover T16 engine +4. It added noise and a little umph.
The real game changer was the Librands manifold. The Rover lump had a cast iron manifold. The Ford has steel pipes so I suspect there is no point in changing the manifold.
Posts: 1,127 |
I had the Librands sports silencer on my 2015 GDI & must say it added a vereeeeeeeeeeeeeeeeeee deep note to the exhaust sound (almost too loud - imho)  . So IF you opt for the Librands specify the "calmer" of the two versions offered... The "oumph" was increased - well: at least the feeling of... + it seemed to rev freer all over. The best solution is to fit a full system, only then you might get significant imporvement on performance ( AND noise...  )
It doesn´t matter how fast it becomes, but how it becomes fast.  2015 Roadster 3.7
Posts: 1,959 Likes: 15
Posts: 1,959 Likes: 15 |
New car looked very nice  last week (think it was you) in between Boreham & Maldon junctions A12. Dove grey Morgan
Posts: 217 |
Thanks for the info , and jochen did you keep the system despite the noise ?. and thanks for the compliment Peter, im sure it would have been me, drove the car back from scotland on thursday and have been driving around that area since ..
Posts: 1,127 |
Thanks for the info , and jochen did you keep the system despite the noise ?. Ouuuh yessssssss Alan - i did!
Posts: 565 Likes: 8
Posts: 565 Likes: 8 |
I have the Librands replacement manifold and cat and it makes a noticeable, positive, difference. I have retained the standard silencer as Rob, Librands, said that the only difference fitting the Librands 'silencer' would make would be to increase the noise but not power. Don't know what effect a replacement silencer would have on a car with the standard manifold and cat but other than more noise I suspect not a lot.
Andrew 'Alice' 2013 Duratec Plus 4. Pearl Blue
Posts: 228 |
I have the Librands replacement manifold and cat and it makes a noticeable, positive, difference. I have retained the standard silencer as Rob, Librands, said that the only difference fitting the Librands 'silencer' would make would be to increase the noise but not power. Don't know what effect a replacement silencer would have on a car with the standard manifold and cat but other than more noise I suspect not a lot. That's good to know. I quite like the sound of my standard system, and I wouldn't say it's particularly quite, but like the idea of a bit more go. It's just a shame the Librand's manifold and cat are so expensive
Andy
2011, 4/4, 2.0, 75th Anniversary 2016, VW Polo GTI 2012, BMW 520d Touring
Posts: 217 |
Thanks Andrew. sounds like a worthwhile improvement, i will probably do the same as you with a better manifold and cat but leave the silencer as is,
Alan
Posts: 158 Likes: 4
Posts: 158 Likes: 4 |
I have the factory-fitted Aero Racing Sports Exhaust on my 2018 Plus 4. I cannot say whether it has more power now (probably), but it definitely has changed the sound a lot, with many bangs during overrun; sometimes it sounds like someone behind me set of fireworks...
