3 members (KennyW, Hamwich, RedThree), 144 guests, and 33 robots.
John V6 63
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,940
Posts838,604
Page 3 of 3 1 2 3
Originally Posted by Royal Lichter
I fill it up for 10-15 seconds then stop for a few to let air out of the tank..
When you say "letting air out" what's really going on is that the air above the fuel in the left hand tank is venting to atmosphere through the vent hose in the upper part of the filler neck as the fuel is 'self balancing' between tanks via the largish hose near the bottom front of the tanks. Which is why if you just pump fuel until you get a (single) auto cut off the tanks won't be completely full as they haven't had time to balance between the two. Not all bad as the issues with over full tanks are well documented here.
Late 2012 M3W
the only issue I have had is if I fill up too far into the pipe, it appears fuel goes into the canister and then it will barley run, until that fuel is gone
Rodger
2004 Plus 8 (wife's)
Said far more eloquently and detailed than I did. :-)
So whats is this? I think it is the fuel vapor canister but what the heck is this tube doing turned up to catch all the debris in the wheelwell?
I was wondering the exact same thing?
2019 M3W 110 Anniversary Black
Previous: 2005 Plus 8
Page 3 of 3 1 2 3
