8 members (JohnMat, John V6, RichardV6, Paul F, MJF, Soleng, Laurens, waikiore),
120
Old Book
Topics49,940
Posts838,606
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
I fill it up for 10-15 seconds then stop for a few to let air out of the tank.. When you say "letting air out" what's really going on is that the air above the fuel in the left hand tank is venting to atmosphere through the vent hose in the upper part of the filler neck as the fuel is 'self balancing' between tanks via the largish hose near the bottom front of the tanks. Which is why if you just pump fuel until you get a (single) auto cut off the tanks won't be completely full as they haven't had time to balance between the two. Not all bad as the issues with over full tanks are well documented here.
Steve Late 2012 M3W
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
the only issue I have had is if I fill up too far into the pipe, it appears fuel goes into the canister and then it will barley run, until that fuel is gone
Posts: 60 |
I fill it up for 10-15 seconds then stop for a few to let air out of the tank.. When you say "letting air out" what's really going on is that the air above the fuel in the left hand tank is venting to atmosphere through the vent hose in the upper part of the filler neck as the fuel is 'self balancing' between tanks via the largish hose near the bottom front of the tanks. Which is why if you just pump fuel until you get a (single) auto cut off the tanks won't be completely full as they haven't had time to balance between the two. Not all bad as the issues with over full tanks are well documented here. Said far more eloquently and detailed than I did. :-)
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
So whats is this? I think it is the fuel vapor canister but what the heck is this tube doing turned up to catch all the debris in the wheelwell? ![[Linked Image]](https://www.tm-img.com/images/2019/09/09/CanisterVent.jpg)
Posts: 135 |
I was wondering the exact same thing?
2019 M3W 110 Anniversary Black Previous: 2005 Plus 8
