1 members (IcePack), 446 guests, and 39 robots.
+8Rich 90
Topics49,841
Posts837,322
#453059 04/06/17 09:04 PM
WarBird Offline OP
WW11 MOG
WW11 MOG
I've just got the engine out to fit new rubber barrels to the Centa compensator - see my other thread
It was quite a struggle to get at the bellhousing bolts, but now I've managed it I'm starting to strip down to the compensator.
I've removed the clutch friction plate seems around half worn, but the pressure plate looks to have got quite warm....
I'm going to fit a new clutch, but before I order...and wait for Morgan parts dept...... has anyone on here fitted an aftermarket clutch?
If so, what was it?
Thanking you in anticipation
When I replaced the rubber centa I handed my first clutch disc which was in good condition because I found a damper spring broken, the clutch disc measures 181 mm the 22 splines of the standard meme as Ford Mondéo diesel or G50 porsche.
WarBird, how many miles do you have on your M3W?
1998 +8
SS Sport tuned exhaust
2013 M3W
Stage ll motor kit
Cats removed
WarBird Offline OP
WW11 MOG
WW11 MOG
Around 9000 miles
Remember that it does get some Motorsport abuse
I was mistaken the 22 splines of the 5 speeds does not correspond to ford mondéo and G50 porsche, only the 23 splines of the boxes six gears mazda that correspond to ford and G50,My tw will have 60,000km.
That is odd. I talked to the shop that is the go to place out of Portland, Oregon and what they tell me the six speed has the same back end and fitting a updated six speed will slip right in.
1998 +8
2013 M3W
Stage ll motor kit
Cats removed
Is there even a Porsche G 50? ???
The G50 is actually a transaxle type used by Porsche, and 911's from that era (late '80s perhaps into the early '90s, I think) are often referred to by the transaxle which was a desirable high capacity unit used in the Turbos, among others.
Late 2012 M3W
The G50 gearbox was first introduced in 1987 in the Carrera 3.2, only appeared in the last year of production in 1989 in the 930 turbo and then went onto use in all the 911's ie 964,993,996 and 997.
22 Plus Four KIMI
12 Plus 4 Sport OZZY
08 Roadster FELIX
06 4/4 70th LOKI
77 4/4 SEAMUS
85 4/4 MOLLY
Ah, a much more complete answer. Thanks
Late 2012 M3W
