Topics49,859
Posts837,498
Posts: 27 |
I'm reassembling a 1963 Plus 4 Supersport that I started work on March 2016. I need a little help with the wiring on the dash panel.
The technical drawing make sense for most of what I've done so far, but I cannot figure out what wires go where for the turn signal (indicator) switch or for the panel light switch. I also what to confirm the wiring for the light switch.
Can anyone help me out with some photos of the back of the dash panel please.
Posts: 1,149 Likes: 19
Posts: 1,149 Likes: 19 |
yep done the wiring this week, do you have a loom do you have the db10 relay box? do you have rear brake light flashing as an indicator or do you have seperate indicators..its a simple job really
phone me or PM me pleased to help its what our morgan community does
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
ps our 1958 car is the new blue silver one on the newest of photos
Posts: 27 |
Ours has the toggles on the dash for panel lights, fog light,etc. We have a 57 also which has a different dash. We bought an entire new harness. The car has separate turn signals and brake lights, but no 3rd brake light.
Where I'm stuck is mainly the panel light toggle switch. I have the red/white white wire for the dash lights, but no idea what goes on the other tab on the back of the toggle switch. Wiring diagrams show a red wire should be going to it from the main light switch from #7 tab. I don't know if I'm supposed to make another wire to go from the main light switch port 7 to the panel light switch.
Also the wiring diagrams for the turn signal switch don't appear to be numbered so I dont know which wire go to which tab.
