3 members (JohnHarris, TalkMorgan, Graham, G4FUJ), 331 guests, and 97 robots.
Topics49,848
Posts837,406
DazMog, The Impaler, tlchzj79
#454890 13/06/17 02:27 PM
DougM Offline OP
I have a 1977 4/4 and the instrument lights are as bright as glow worms in a jam Jar any suggestions how i can make it so that i can see the instruments when in the dark
Doug
1977 4/4 4 Seater Royal Ivory
There is a dimmer switch hidden under the dash, probably on the LHS of the steering column. Is it set at full power?
Is it possible to change the bulbs to LEDs? I changed to LEDs for my warning lights, indicators and main beam- a big improvement.
Gerry
I have some replacement LEDs for the instrument lights but they are very white. I am playing around with some filter material to change the colour temperature from cold white to warm white. If all balbs were changed for the cold white LEDs it would probably be OK. LEDs may well be the answer to instrument misting.
