8 members (Hamwich, Sir Percival, SteveT, Chris99, uvk33n, MJF, sid, Saxonian), 207 guests, and 21 robots.
+8Rich 99
John V6 57
Topics49,909
Posts838,132
kennyh Offline OP
The Morgan is new and coming up for its 1000/3 month service in July, done 400 miles so far in between the showers.
I've read all the threads on here and taken the advice of procuring a nice twin valve Wanner for the odd 1000 mile top up should I need to.
Suggestions for grease seem to be either the Lucas Red stuff or Comma Moly.
Just thinking though, is it probably best to find out what Oakmere will be using (as they will be servicing the car whilst under warranty) and fill the Wanner with that instead of possibly mixing and matching? The car will be very lightly used so I don't think it's a huge issue anyway but just curious what other guys do and reckon.
Cheers.
I'd either do what you suggest and find out what Oakmere will use or tell them not to touch the kingpins and you'll do it yourself.
1972 4/4 2 Seater
I use whatevers cheapest of the correct grade from my local lubricants suppliers. Job done!
Arwyn
SBM Offline
Arwyn
After faffing about with various sorts & colours, this is about right now..
Life is too short to argue about oils & greases I think.
The bottom line is it won't matter. I've used all sorts and have come to the conclusion that grease is grease. Just do it little and often and you'll be fine.
2008 4/4 1.8 Duratec
Throughout 40 years of Morgan ownership I've always used Castrol LM.
Castrol LM or red & tacky
Ray Offline
used all sorts of grease for forty six years , does not seem to matter
Originally Posted By SteveT
it won't matter. Just do it little and often and you'll be fine.
These. Definitely.
Black Rat
Black Rat
+ 1 every 700 miles, 32k and no play joy
Keith
2013 narrow bodied + 4 Ruby.
